Question about Compaq Presario 700 470024-192 Notebook
Distorted display Circular objects appear somewhat flattened. Where are the width and height adjustments that appear on most monitors?
  • Compaq Master
  • 5,569 Answers
LCD displays are not controlled the same as CRTs so the typical adjustments are determined by settings you will find under 'Display' in the Control Panel.
The horizontal and vertical resolution are probably currently misset.
Posted on Aug 15, 2008
  • 876 Answers
Control Panel>Display
SOURCE:
IF LENGTH and WIDTH are given How to find Hight
Never. Even if it a regular shape.
Oct 18, 2016 | Miscellaneous
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
Jul 04, 2010 | LG Flatron W2242P-SF 22" Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Width and height ratio
You need to set your PC video output resolution to the native resolution of this monitor, which is 1680X1050 @60Hz.
Right click on the desk top, the display properties will come up, click on setting tab, then you will see resolution setting choice.
Mar 28, 2010 | Acer AL2016W 20" LCD Monitor
I m using acer moniter,i got the probs with its screen display..width of the screen is expand until max n now pic doesnt look good because width is wider then its height...can u pls assit me how to decrese...
You need to set the PC VIDEO resolution to the native resolution of the monitor to get correct aspect ratio (not adjustable at the monitor, the adjustment is doen at the PC VIDEO card setting), you need to find that out from your monitor owner manual.
Mar 22, 2010 | Computers & Internet
The screen is stretched there is nothing distorted
What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
May 29, 2009 | Acer AL2216WBD LCD Monitor
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
Screen width unadjustable
chk the resolution is as mentioned by the makers in the user mannul.
Jun 16, 2008 | Computers & Internet
My new 19 inch 1952 LG monitor stretched my display picture from what I use to have on my 17 inch. How do I adjust the height to width ratio for a picture that isn't distorted?
Right-click your desktop, click properties
go to 'settings' and select the 19 inch monitor
now change the resolution to the format you want to use.
Set it to something like 1600x1200, or 1024x768
Apr 04, 2008 | Computers & Internet
MS Frontpage and Macromedia Flash
There should be a tab to enter HTML. Once in there just put in something like this: Adjust your height/width and name accordingly. This is the most basic of codes and there are a few FAQs out there if you want to get a little fancier with it.
Aug 23, 2007 | Microsoft FrontPage for PC
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
