Question about NTL VS1500 Cordless Phone
NTL VS1003 cordless Phones After use the phones don't stay charged without pressing batteries and cover. Do I need replacement batteries ? If so can you say where they can be purchased in Ireland - Drogheda area ?
3 Suggested Answers
SOURCE: NTL VS1003
I have the manual if you still need a copy, or me to answer questions sbd64000@yahoo.com
Posted on Sep 23, 2008
  • 15 Answers
SOURCE: NTL VS1003 Cordless Phone Problem
You should be able to download a copy of the manual at :
www.cordless-phones.uk.com
Hope you find the solution there!
Posted on Mar 01, 2009
Which battery cell is better for ntl cordless vs2000?
Please replace with same rating/type as given on cell that is normally NI MH, Rating current rating - 600ma, 900ma, higher ma means lasts longer after charge. Brand- panasonic, sanyo, any standard brand, initially charge for 10 to 12 hours. Pl do not keep hand set always on dock, this overcharges the battery, shortening cell life.
Jan 07, 2015 | NTL VS2000 Cordless Phone
Battery wont stay charged
I've had the same problem with my Uniden DECT 6.0
You need to buy a new battery. Almost every electronics store that sells phones should have 'em
Hope it helps!
Oct 04, 2012 | Uniden DECT 6.0 Cordless Phone ID
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Dec 03, 2011 | Panasonic KX-TG2383 Corded Phone
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    Brand new phone, will not charge. have plugged it in. batteries test out ok. however it looks like the base units are not picking up the charge. brand new phone. trying to use it in bangalore india where...
    Take it back to where you got it and demand a replacement. Usually I stay far away from extended warranties but in the case of telephones I make an exception. They are made very cheap these days and don't last very long.
    Aug 20, 2011 | Panasonic KX TG4053 19 GHz Trio Cordless...
    I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
    Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
    Jul 12, 2011 | Uniden Cordless Phone
    Need a instruction maual for NTL VS2000
    Hope this is what you are looking for.
    Please save a copy to your hard drive. Or better yet, print it and then store it for future use.
    http://www.cordless-phones.uk.com/userguide/vs2000.pdf
    Nov 27, 2009 | NTL VS2000 Cordless Phone
    How do i put the ring tone back in the handset
      Does the Phone Power Up?
    1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
    2. Does the Battery Hold a Charge?
    3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
    4. Listen for a Dial Tone
    5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
    6. Listen for Static
    7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
    8. Verify Your Handset is Registered
    9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
    10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
    11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
    12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
    Nov 17, 2009 | Uniden Cordless Phone
    Sep 01, 2008 | NTL VS1500 Cordless Phone
    NTL VS1003
    Feb 10, 2008 | Lands Phones
    NTL VS1500 Cordless Phone Logo
    Top NTL Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Cliff
    David Burbee
    David Burbee
    Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
