Question about Audiovox Jensen Msr2007 Am/Fm Satellite Ready Receiver
Have a msr 2007 jensen...no response to buttons...just a single beep..stereo is on but will not turn off...batt is fully charged and i have tried reset button a dozen times...any suggestions
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
I just bought a Jensen smpv-2gbub player. How do
How to charge the Jensen MP3 player - Model smpg-v2bub
Ignore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1. When computer is on and at windows screen, attach cable from computer to mp3player with mp3 turned player off. It will immediately show you a connect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3. Now turn the mp3 player on by switching the button on the right side of the device to the on position. It will suddenly show you it's charging - the battery on the front of the mp3 player will have a signal pulsing through it.
4. It will turn off after one minute. It's literally half charged now. Strange I know. Repeat from step 1 and it will fully charged.
If it doesn't fully charge after it turns itself off after 1 minute the 2nd time, then repeat steps from 1, one more time, but this time when it turns itself off after a minute, still leave it connected to the computer for 10 mins even though it looks like it's off. Then disconnect it physically from computer, turn it on with the on button on the right side, press the left side middle button twice and look at the battery on the screen - it should be fully charged now.
Apr 07, 2010 | Jensen Audio Players & Recorders
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Jensen SMPV-2GBUB wont turn on or charge
How to get the Jensen mp3 to charge - model smpv-2gbub,
transparent-pixel._v42752373_.gifIgnore instructions that came with it - they don't work.
1.When computer is on and at windows screen, attach cable from computerto mp3player with mp3 turned player off. It will immediately show you aconnect screen on the mp3 player.
3.Now turn the mp3 player on by switching the button on the right side ofthe device to the on position. It will suddenly show you it's charging- the battery on the front of the mp3 player will have a signal pulsingthrough it.
4. It will turn off after one minute. It's literallyhalf charged now. Strange I know. Repeat from step 1 and it will fullycharged.
If it doesn't fully charge after it turns itself offafter 1 minute the 2nd time, then repeat steps from 1, one more time,but this time when it turns itself off after a minute, still leave itconnected to the computer for 10 mins even though it looks like it'soff. Then disconnect it physically from computer, turn it on with theon button on the right side, press the left side middle button twiceand look at the battery on the screen - it should be fully charged now.
Jan 30, 2010 | Jensen Audio Players & Recorders
The camra turns on than beeps three times and turns off.
1 makessure it is fully charged
if it is
2 take batt out for about 30 minits try again
3 take out mamory card and see if it turns on without it in
4 if all elts fails go to manufacturing website or forum to see if someone has your same problem
Oct 29, 2009 | Samsung Digimax S630 Digital Camera
Put in a CD and now it is smoking. 2007 Charleston Motorhome
This is Caused by a Bad Ground. Locate the Ground Wire for the Stereo and ReRoute the Ground to a Better spot on the Body.Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 28, 2009 | Jensen CD4610 CD Player
Phone appears to be dead in spite of being fully charged
just bring it to a certified service personnel, dont try to open it by yourself. maybe you can do something on the battery, try cleaning its battery terminal, not with liquid...just scratch it with something sharp or pointed, just be carefull ok?....then place the batt again on its place.
Jan 14, 2009 | Nokia 6030 Cellular Phone
My jensen mp7610 car cd player
I asked a friend of mine and he didn't charge me ANYTHING. What happened to free advice? What has happened to helping each other out? This is bogus!
Sep 28, 2008 | Jensen MP7610 CD Player
Audiovox Jensen Msr2007 Am/Fm Satellite Ready Receiver Logo
73 people viewed this question
Top Audiovox Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Audiovox Boating Expert? Answer questions, earn points and help others
