Question about Sony KV-35S26 35" TV
I have a Sony KV-35S26 manufactured Aug '97. The picture comes ON only occasionally. When it fails to come ON, the standby light blinks continuously. Sometimes, the picture comes ON initially then goes out after several minutes. The picture looks fine when its working. Audio works fine. I removed the back cover and inspected the soldering, wires and connectors but found nothing obvious wrong. Just before the picture goes out, the image being displayed collapses vertically then I see a series of bright white horizontal lines across the screen. This all happens within a fraction of a second.
    Novelist:
  • 123 Answers
After 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 14yrs old itseems TV TUBE is still in good condition because you have said that whenever display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
Posted on May 22, 2011
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
Sony KV-34xbr800 standby light flahes all the
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
Jan 11, 2010 | Sony Televison & Video
My sony kv-35s26 tv will not turn on
check your standby light to see if it works if not then have someone to check your power supply and horizontal circuits
Nov 10, 2009 | Sony KV-35S26 35" TV
Standby light stays on
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
Thanks,
Dan
Aug 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
