Question about Sylvania G-Netbook
My netbook will not connect to the internet even though it shows that there is a good signal
    Genius:
  • 1,267 Answers
It really is lying to you, as it needs something else to connect to the internet. Namely, a network key that you have to enter in order to access your WiFi network. That network key is the "password" that your network was setup wit in order to stop others from signing on to your network. See the detail below to access your network.
It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on it's backand using a toothpick, insert it into the little hole about an inch diagonallyfrom the right corner of the data plate, this will re-load a new copy ofeverything including the WiFi RT28701 driver. sometimes thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Posted on May 26, 2011
Hello, I'm trying to connect through a landline but can't connect. even though the landline and wireless show that they are getting a signal it still won't let me connect with the internet. Ichecked the...
Try going through the control panel, Internet options, (Vista, Network and Internet ) And choose Connect to a Network. Go through the process.. walks you through.. Hopefully this will do it..
Good luck
Apr 30, 2011 | Toshiba Satellite L305-S5907 Laptop
I have an ebook notebook 7 but it wont load the internet even though it is saying im connected with a strong signal. any advice?
just because you are connected to a wireless network does not necessarily mean that you can access the internet. Can you access the internet from another wireless device using the same wireless network. If you can then the problem lies with whatever browser you are using and maybe your firewall. Please reply with what windows version you are using and what browser and firewall is on your ebook
Mar 20, 2011 | ASUS Eee PC 1000HE Netbook
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
Can not display internet explorer web page but it shows i have a good wireless connection
You have just a local connection between the router and the computer, your router does not have internet connection, the signal received is just the router. Check with your phone or cable company or the company that provides you internet
Jan 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi there I cannot get my laptop to connect to internet even though it says there is excellent signal, status is limited or no connectivity. I am really not technical so please answer in the most simplistic...
Where it shows about the signal, the Icons bottom right? Right click on it and click troubleshoot. It should check everything out. Where is the wi/fi at? Your house or in public. You may have to type in the numbers on the router. Or turn it off and back on.
Dec 17, 2010 | Dell Inspiron Mini 10v Netbook Computer
I can't get internet connection even though it says my connection strength is "excellent."
The netbook is working fine. The WiFi connection or SPID may require you to login as in it is a protected signal. The "Excellent" means that you are receiving an excellent signal from the router. What you want is internet access which is upstream of that. Try a different SPID or connection.
Nov 25, 2010 | Sylvania G-Netbook
Acer D150 Netbook - I get a good WIFI signal but internt explorer will not connect. Get message "Internet Explorer cannot display the webpage" My connection shows very strong signal. This is a public...
go to my network place then go to local area connection logo and right click on it then go to propeties after that u will see a window crew down to TCP/IP once u are thr click on properties to ur left then fill in the code after than click okay and make local area connection your default connection. thats it u are done
Nov 03, 2009 | Acer Aspire One D150-1587 Netbook
Internet connection not detected
Try desconecting the router for a few minutes. Then turn off your pc and power on again your router and pc.
Feb 26, 2008 | Linksys Wireless-G WRT54GS Router...
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
