Question about Sharp Televison & Video
We have a dish sat. and it says to press select to watch tv. we see no select button to do so. We have just purchased Sharp tv, model # lc-c3242U, please help
    Brigadier General:
  • 6,966 Answers
Depending on how the satellite receiver is wired to the Sharp TV. I suppose your best try would be to select the input source on the Sharp, something like AV1 or Video (1) not channels. Channel selection would be done on the remote of the satellite receiver.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 15, 2008
SOURCE:
Why won't my LC-C3242U Sharp Aquos tv won't turn on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 06, 2014 | Sharp Aquos Televison & Video
DIDN'T TAKE THE SELECT BOTTON TO WATCH TV AN MY 2ND TV.
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. The first troubleshooting step you are going to want to try is making sure the remote is in SAT mode you can insure this by pressing the SAT button once the remote. If the remote is in SAT mode and still not functioning properly you may want to try replacing the batteries if you already have not. If both options do not work for you then you are going to need to try readdressing the remote to your DISH receiver box. I will list here for you the instructions on readdressing your TV2 remote. I hope you find this information useful and if you have any further questions or concerns feel free to email me at [email protected]
Instructions for addressing remote to DISH receiver
  1. First you will want to take your TV2 remote to your TV1 location where the DISH receiver box is.
  2. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver or pressing the menu button twice on the TV1 remote.
  3. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  4. Hold down the SAT button until all mode lights light up.
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number in the little white square to something different than what is already listed for secondary remote address.
  6. Press the pound (#) button.
  7. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 5 will appear in the System Info screen under Remote Address.
Mar 09, 2011 | DISH Network IR Remote Control
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Nov 06, 2009 | Televison & Video
When i turn on the tv it goes to a Dish Screen when i push select it doesnt do anything
I most likely need additional information to ensure this is in fact the correct resolution to your remote issue- but it sounds as though the remote may be in tv mode. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, which will enable you to be able to press select to proceed past the DISH Network screen. The "SAT" button is labeled & in the upper left hand corner of the remote just press SAT once and then release, the button should briefly light up red & then will go off, you can then press select and as long as the SAT button lights up when you press select or any other button on the remote then your all set to go! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Sep 29, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Have Sky plus and the remote does not accept any codes I have got, so no volume control via Sky remote. Do you have the correct code for a Sharp Aquos 46" ? Thanks
please follow the steps below:
TV
RED + SELECT
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I get the volume to work on my sky remote control?
SHARP TV
TV
RED + SELECT
TV
0093 (sharp code)
press the power button if this turns your TV off then press SELECT to save. If not press TV then POWER. repeat this step until it does turn your tv off remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Sep 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Polaroid Model TDA-03211C
Our tv sharp aquos LC 52 GD^U 52 in. HDTV LCD plays a narrative along with the closed captioning on selected channels, especially channel 2. We cannot get it to turn off and it is annoying to the point of wanting to return the tv. Please help.
Jul 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
