Question about Dryers
My whirlpool dryer is making a very loud noise when on< sounds like it is destroying everything in the dryer. i checked the dryer hose all clear of debris!!
    President:
  • 3,074 Answers
You will need to open up the dryer, make note of the belt routing and remove the drum as the drum rollers/glides are bad, here is a website. Hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
belt routing:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Posted on May 22, 2011
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
Whirlpool dryer awz123 make loud noise
sounds like a bad tub wheel that the drum rides on ,just take the front off look in the back ,there are two wheels that the tub rides on ,go to your Sears parts dept with the model number ,get the part easy job
Jan 15, 2013 | Dryers
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Dec 12, 2009 | Whirlpool ET8CHEXSQ Dryer
Rattling noise
you might have something in the blower wheel. it is common to have something fall down the vent and the blower wheel is hitting it.
Oct 11, 2009 | Whirlpool Dryers
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Whirlpool gew9200lw1, dryer does not heat everything checks out ok, replaced electronic control worked for a day then stopped working please help. The sensor and wire harness reads a short and no...
if limit switch has no continuity than it is bad,the heater will not come on.before you change the switch you nead to make sure that you do not have a blockage in your vent hose,make sure vent hose is clear from dryer to outside vent.a blockage in the vent hose will cause the high limit switch to go bad.
Jul 03, 2009 | Whirlpool LER5636P Electric Dryer
Dryer vibrates with exhaust hose attached
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
