Question about Health & Beauty
I have just recieved a Lady Braun Elegance shaver Model # 5660 and it works but does not shave properly. It looks brand new but may need replacement parts. What do you suggest?
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
VtToolMan
  • 704 Answers
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
Testimonial: "very helpful"
brector3
  • 1625 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
brector3
  • 1625 Answers
SOURCE: Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Posted on Apr 08, 2010
Testimonial: "Fast turnaround on the response with an very easy to follow answer."
Cytherian
  • 124 Answers
SOURCE: Looking for a service manual for the Braun 7570 syncro razer
It's actually easier than it looks. On the bottom of the shaver is the charging port. That black plastic piece surrounding it can be pried off. Do it carefully, so you don't dent/scratch the casing. Once removed, the side pieces easily remove. You'll now see screws holding the body together. Have at it. :-)
Posted on Nov 07, 2010
My Braun shaver 7 does not work without cable, the battery is full but hygine indicator is red,what should i do? It just works with cable and shaves good.
Most likely, the battery needs to be replaced. A replacement battery can be found at shaveroutlet.com. You will need to know your shavers specific model number to select the correct battery type
Dec 11, 2016 | Braun Health & Beauty
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
How can I clean my braun washable series 3 (330) shaver. better. I can take it apart so far but just cant get under the blades
This model uses a 'shaving cassette'. The blades can not be removed from the foil assembly. Braun's instruction is to simply rense the shaving head under hot running tap water. Unfortunately, this does not work very well over time due to the poor design of these parts. Once they become clogged up it is usually necessary to replace the cartridge.
If replacement is needed you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jul 27, 2011 | Health & Beauty
Bought a Braun series 3 razor (#340 wet and dry). It hardly shaves the whiskers but it really messes my skin up. ( I was using a Norelco which did a pretty good job) I think there is something wrong...
You should be able to run your finger over the foil mesh on the Braun shaver to feel if there are any rough spots causing the problem you describe. If there is damage you may also be able to see it.
It could also be that the Braun shaver simply does not agree with your skin type. There are many people who are sensitive to different kinds of shaving methods. Foil shavers like Braun may not be the type of shaver for you
Apr 04, 2017 | Braun Syncro 7680 Electric Shaver
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
http://shaveroutlet.com/shavers/foil-shavers/braun-series-3-370-men-s-shaver.html
http://shaveroutlet.com/shavers/foil-shavers/braun-1775-series-1-shaver-p-123.html
Sep 07, 2010 | Braun 360° Complete 8985 Electric Shaver
Looking for new blades for a Braun Electric shaver model 7630. Where can we get them and cost. Live in Gauteng, South Africa
$21-$70 from 3 pack to 12 pack
http://shavers-and-replacement-parts.stores.yahoo.net/braunshavrep.html
$28 + http://www.nelsonappliance.com/braun+shaver+parts.asp
$28+
http://www.newcomerscns.com/index_braunfoilncutter.htm
$19.99
http://www.thepartsbiz.com/Braun-7000-Series-Syncro-Pro-Shaver-Blade-And-Foil-Genuine_p_4827.html
$10
http://www.thepartsbiz.com/Braun-7000-Series-Syncro-Shaver-Blade-And-Foil-Aftermarket_p_791.html
Jun 23, 2010 | Braun 4501 Electric Shaver
Is the Braun Activator8595 a good shaver for extra sensitive skin
The Braun foil shavers are well designed and I find they work well for sensitive skin if you prepare properly. Make sure you apply a hot towel to your face followed by a shaving conditioner. When applying the shaver, press lightly. Don't be afraid to go over the same areas several times to get most of the whiskers. Once you do this for about a week, your skin should begin to adapt to the sensation of electric shaving. You'll then be able to use the shaver more aggressively and get a thorough shave.
Apr 04, 2010 | Braun 360° Complete 8985 Electric Shaver
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
Feb 19, 2010 | Braun 4501 Electric Shaver
Shaver started making a much louder buzzing sound, no longer shaves as well and now hurts a bit to use. Can this be fixed?
Hello Robert, It sounds like the foil screen might have been damaged and is causing poor shaving performance. Typically, a screen will get small holes or tears in it after providing good service for some years, however, these very thin screen foils, can get damaged other ways too.
The best way to restore the best shaving performance is to replace both the foil screen AND the cutter head block (cutter head) as it could be possible that the cutter blades have become damaged or nicked and have caused the foil screen to become damaged, as a result.
I would contact www.electricshaver.com and see if you can purchase a new set of the cutter block head and the screen foil for your particular Braun shaver model. As the Braun 360 is a tradename used on a couple of different model numbers, you really need the four (4) digit model number in order to locate the correct replacement parts.
Here's a link to their page with the various Braun replacement cutter blocks and foil screens. You might find your model number amoung them, otherwise, you can also give them a call at 1-888-476-1785 and ask them to assist you with selecting the proper replacement parts.
http://www.electricshaverstore.com/get_list_125.htm
As you are no doubt aware, replacing the cutter head and foil screen is the best and simplest way to restore an electric shaver to a like new shaving condition and much less expensive than replacing the entire shaver.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Braun 360° Complete Electric Shaver
Head (foil and blades) used to last 10-12 months. Now they last about six weeks. I don't hink I have done anything different when shaving. Braun Syncro is abotu four years old.
Six weeks? That's very peculiar. Are you certain that they are seated properly on the shaver? If there's a problem with the head and they're not fitting into place slightly off, they can end up wearing out faster.
If you've used your shaver for a number of years, your best bet is to probably step up to a newer model Braun shaver. The 7000 series was OK, but the 8000 series is much better. You can still pick up new old stock ones off "that auction site". They shave not much differently from the new 9000 series (Pulsonic). Good luck!
Sep 16, 2009 | Braun Syncro 7526 Electric Shaver
Health & Beauty Logo
70 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
