Question about Garden
I have a yardman (kawasaki/mtd) 6.5 hp. self propelled mower and it wont start. I cleaned the carb. blew out and cleaned all gas and air lines, changed the spark plug twice and still nothing. All that happens is a short "thud-dud-dud"(like it wants to start), followed by puffs of white smoke out of the muffler and air cleaner box. I also noticed the spark plug keeps getting soaked in oil and I took the muffler off and there was also a puddle of oil in there. Is it trashed? is the timing off or something? I'm outta ideas, any suggestions?
  • 6,674 Answers
Has it been sitting and not used for a while? If yes, try removing spark plug and pouring WD-40 or similar penetrating solution in to cylinder through spark plug hole and let it sit in there for a while, (overnight if you can) to loosen oil and compression rings. Dump it out as well as crankcase oil next day and add fresh oil. Now try to start, and use WD-40 spray as quick start spray in throat of carburetor to prime it, and see if she'll go. Had a few lawnmowers do the same after sitting , and this actually worked quite well in getting them going again. Once it starts and gets some running on it, the rings will usually loosen up and be ok., at least for another season.
Posted on May 23, 2011
Wont start gas
squirt some starting fluid in the carb see if it will startif not chek for spark at plug if fireing check gas for water after that remove float bowl from carb clean it out replace plug and it should start
May 18, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Mtd yardman wont start getting feul no spark detected
they go bad rarley make sure your blade brake switch is not ingage killing spark
Apr 19, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yardman 6.5 HP XL 21'' CUT S/N#D06786CN
See if it will start with a little splash of fuel down the carb.
If it starts for a second you probably have a plugged main jet.
The mowers collect a little bit of fuel in the bottom of the carb and then water comes along and it makes rust and gunk and turns the brass stuff all green. You remove the main jet and clean the two holes on the bottom and the little tiny hole at the top of the threads *(you should wire brush the threads and get a tiny piece of wire strand to clean this jet.)
I know you ran the mower till it ran out of gas....but that was only till it ran out of enough gas to fuel the main jet. There was still fuel residue in the fuel line and the bowl.
This should be a fast fix though. Good luck and be careful!
Jul 18, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Starts but when chock goes off stops running Honda engine Yardman self propelled mower
OK take and check this. A lot of the honda engines,especially push mowers,tillers and pressure washers,they put a type of coating inside the gas tank. The bad thing about this type of coating is it has a tendency to peal and wash into the carb. I would look inside the tank to see if there is any debris. I would also clamp off the fuel line and take out the bolt that holds the fuel bowl on and catch the fuel that drains out in a clean tray. If it looks dirty,pull the carb and clean it,it should fix it.
Aug 09, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Where is the carb on a yardman 6.5 hp?
It will be by the push to prime button, and under the air filter.
Jul 07, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
