Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
  • sarahtee May 25, 2011
    yeah I tried to put it in a different computer and nothing happens nooooooooooooooo omg all my music and improtant pictures are gone D: this really sucks...
    Brigadier General:
  • 10,406 Answers
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
Posted on May 22, 2011
  • sarahtee May 22, 2011
    but this one has all my really important pics on it D: and I tried it in all the ports none work I put a differnt usb in my comp and it worked fine.
  • ikkenom May 25, 2011
    Did you try a USB port on a different computer?
    If it is "dead" on multple computers, then your files are "gone". Period.
How to find Sandisk cruzer 4G USB drive serial number? Embeded serial number how to find
Try using Belarc Advisor with the USB drive plugged in. Read the report to get the serial number. Hope this helps.
Mar 14, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 8gb cruzer filling itself up???
see if this happens on other computers. If on other computers you have malware on the device itself. If only on one computer then the computer has a malware or configuration problem. Maybe temp files are set to go to path that the usb stick gets when it's inserted. Identify the source of the issue then solve. stick vs machine
Nov 08, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a sandisk cruzer, led continuously lights
I"ve seen a couple of these do this and the flash disc is broken and not working. Probably nothing you can do to fix it.
Sep 30, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to use a memory stick
take the cap off, plug the device into a usb port and your computer should read it, then you can drag and drop files into it =)
Sep 21, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How can i use an usb memory stick (4GB) on an iMac running Apple OS Snow Leopard? I would have to format one to use it on a Panasonic BlueRay Disk Player!
plug it into your computer and go to my computer then click on the usb memmory stick and drag stuff over to it like files etc. :D
Sep 13, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Heating up and shutting down
it is due to viruses try kaspersky internet security 2009,panda antivirus,norton or mcafee
most likely kaspersky can fix it
Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
209 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
