Question about Mitsubishi Televison & Video
How to set up a Mitsubishi VCR HS-721V - Mitsubishi Televison & Video
SOURCE: Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Posted on Nov 13, 2007
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
There is a reset for this problem and it worked for my VCR. This was a last resort without the manuel.
Only someone with electronics experience should do this.
Posted on Nov 26, 2007
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
Gigatech
  • 259 Answers
SOURCE: Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Posted on Mar 10, 2008
  • 127 Answers
SOURCE: I need a manual to
It is my pleasure to guide you.
I am sorry but the news is that this model has no free downloads that I could find. Click the link below to purchase the manual.
QUOTE
MITSUBISHI HS-721V(B) - It's a full owner's manual ( also known as operating manual or user guide), and it's in PDF format. After placing order we'll send You download instructions on Your email.
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=52323
MITSUBISHI HS-721V(B) Owner's Manual $9.99 Shipping costs-download: $0.00
Link to this manual is usually sent within 5 / 6 hours (max. 24 hours).
UNQUOTE
If your set is still under warranty then you could contact the store for a new manual or
CONTACT them at
MEVSA PARTS DEPARTMENT
Service parts including instruction books and remote controls I would try this one
phone: 800.553.7278
fax: 800.825.6655
MEVSA CONSUMER RELATIONS
Product Information, Brochure Requests, and Customer Service Assistance I would try this one
phone: 800.332.2119
MEVSA WARRANTY DEPARTMENT
Mitsubishi Extended Warranty Programs
phone: 800. 888.8245
fax: 949.609.4912
Document Fax-Back System
Mitsubishi Electric Visual Systems America, INC (MEVSA) I would try this one because of the email address
9351 Jeronimo Rd. Irvine, CA 92618
Email:mdeaservice@mdea.com
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Posted on Jun 13, 2011
Where can I find a manual?
1. You might try mitsubishi.com. They have some VCR manuals available for download.
2. If no luck there, I suggest you go to ebay.com and search for:
"Mitsubishi HS-U680 VCR". Scroll through the listings and you may find someone who has listed a manual for your HS-U680.
Apr 20, 2016 | Mitsubishi HS-U680 VHS VCR
I need a manual to vcr mitsubichi hs 721v
QUOTE
UNQUOTE
CONTACT them at
phone: 800.553.7278
fax: 800.825.6655
phone: 800.332.2119
fax: 949.609.4912
Jun 13, 2011 | Televison & Video
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
I contacted Mitsubishi support. It is very likely the 510 and the 520 are similar. I was told to look at the back of the VCR (in the middle and lower) for a "timer reset" button. Pushing it will put you into initial setup mode and you can set your VCR to english menu. It works!
Ronrr
Jul 14, 2008 | Televison & Video
Mitsubishi HS-u59 video cassette recorder
You will have to choose a year that corresponds to the days of the week. In other words, the processor has not been designed to accomodate that far into the futured\...accordianman
Feb 11, 2008 | Mitsubishi HS-U775 S-VHS VCR
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Televison & Video Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
