Question about Garden
Im trying to adjust the drive control oa a Husqvarna, the adjust knob on the handel will pull out but he knob wont turn. i got a husqvarna model number 55 R 21 HV
    President:
  • 3,074 Answers
Turn nut on the underside of drive control is to increase drive speed. Hope this helped Tim
Posted on May 22, 2011
Husqvarna wb53se mower self drive needs adjusting
Remove cover on the wheel, tighten the ball bearing idler. Should be 3 thumb screws to remove cover.
Feb 20, 2012 | Husqvarna Garden
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Apr 23, 2010 | Husqvarna Viking 1
Chain wont go around the pully inside casing and chain is right s
I think you need to adjust the bar back toward the motor -- this shortens the bar and allows the chain to go around the drive gear. Then you adjust the bar outward to tighten the chain.
The adjuster would be a screw or a knob near where the bar attaches to the motor -- turning this adjuster moves the bar -- either away from, or toward, the motor.
Mar 26, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I just bought a used Husqvarna 2000 sl without a manual.
If you have on old Husqvarna 2000 from the 1970's, then the knobs are as follows:
Top front left: Pattern Selector
Top right: Stitch width
Lower: Stitch length and buttonhole (when turned to 0 and pulled out)
Extreme left: Upper tension
Side left: Presser foot pressure
Jul 19, 2009 | Husqvarna Viking 1
MOWER CONTINUES TO PULL AFTER DRIVE CONTROL IS RELEASED
try and slacken the adjuster nut on cable mate there shoul b 1 smwhere at top of cable near drive control lever/handle and also 1 at drives gearbox. failing that mate it could be a tensioner spring on the drive control mechanism
Apr 16, 2009 | Husqvarna Garden
Husqvarna 41 chain saw wont run except with choke pulled in and o
Start at 1 turn out. After warm up adjust for best operation. Don;t lean out high speed screw.
Mar 21, 2009 | Husqvarna Garden
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
