Question about Refrigerators
The green light on my Beko ZS430 freezer, is not uliminated, but the freezer is working fine. How do you go about replacing the indicator light section for this freezer,
  • 1462 Answers
SOURCE: freezer indicator green light not
assuming temperature ok, it will be just the nean light and does not affect operation
Posted on Jul 11, 2008
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
garing
  • 998 Answers
SOURCE: Green indicator light not working on Beko freezer
should pry out
thumbs up
Posted on Aug 17, 2009
aasc
  • 1606 Answers
SOURCE: GTS22KBMBRWW GE refrigerator; the compresser does
Due to the compressor not coming on , this is an indication of a bad main control board . Part number WR55X10942 . Occasionally , if you remove the board ( behind the 8"X10" panel , on the back of the refrig ) , and look on the soldered side , just behind the small black boxes , you'll see a spot , which has become unsoldered . You can re-solder this spot , and the compressor will run . If you do not see the spot , then the module is bad , and the control board will have to be replaced .
Posted on Sep 27, 2009
Moved the fridge on Wednesday and the green power indicator light is out but the fridge freezer appears to be working fine- do I need to get someone to check it or is it probably just the bulb?
If the unit is working fine in all respects, it is not cost effective to have someone come out and repair/replace a bulb/led.
Forget it.
Jul 31, 2015 | Refrigerators
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
My mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Dec 15, 2009 | Refrigerators
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Danby 3.6 cu ft freezer
If it is out of warranty the cost of repairing it may be more than the cost of replacing it.
Mar 09, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
