Question about AudioBahn A2002T Car Audio Amplifier
Amp constantly blows fuses as soon as power wire is connected. anyway to fix?
  • Ryan Armour May 23, 2011
    Which fuses are blowing, the in-line fuse, the built-in fuse on the amp (if there is one), or both?
  • AudioBahn Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you
amp constantly blows fuses as - amp-constantly-blows-fuses-as-otfyjrky3pc2prtgltcdyqtn-3-0.jpg
Posted on Feb 03, 2015
The two fuses on the amp itself
Posted on May 23, 2011
Amp want power off
Hello
If your Dual Car Amp refuese to switch ON check the following.
+12V wire is not connected or incorrect voltage.
REM wire is not connected or incorrect voltage.
Ground wire is not connected.
Fuse(s) are blown.
If the fuse blows repeatedly, check whether the +ve voltage wire touche the chasis of the vehicle. If it is OK, the fault is with the univt itself. That is, the output of the unit has a short. Check for any output IC failure. OK.
May 11, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
As soon as I start the gs500f a 20 amp fuse blows and I have no electrical power and the engine also shuts off
Sounds like time to remove the fareings, gas tank and seat.
There may be a loose somewhere on the bike. Remove the seat and gas tank to gain access to the wiring harness. Get a volt Ohmmeter as you may need to check continuity at various points. Start at the battery, then the fuses and the wires connecting to the fuses. Inspect for burned wires, abraded wires, loose and/or dirty connections, bad connectors and loose wires. This means the mass of wires inside the headlight must also be inspected. Check the handlebar kill switch and the side stand kill switch as well. Go all the way to the ignition system. Check the key switch. Put it on "run" and check for power through the switch as you jiggle the wires. A spark can blow a fuse. A hot wire thst is going to ground due to an abraided wire will blow a fuse. a bad electrical part like a shorted horn, headlight or switch can blow a fuse. Find the bad connection and you should be able to fix it.
Can I get a “very helpful” rating on this answer?
Aug 25, 2009 | 2006 Suzuki GS 500 F
Blowing fuses on the Vosonik VB101PK
ok, always use ground and positive from speakers to the amps +/- . Make sure the amp is not grounded. Some amps are made of metal and will ground itself. When ever any fuses pop, this means that something somewhere got grounded. If using metal srews to mount amp that has a metal casing, chances are you will pop a fuse or two. Be careful ajusting the speaker wires with a metal srewdriver, I've done that alot. "POP"
Jun 21, 2009 | Visonik V117SX Car Audio Amplifier
Wont power on after checking all the wires
HI DUDE PLS CHECK UR REMOTE WIRE IN UR PLAYER .... U MIGHT BLOW THE FUSE .. ... THE CONNECTION IN REMOTE WIRE WILL POWER EVEN THE FUSE BLOW ..
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
Fuses blowing
It may not be your amp at all, disconnect the power wire from the amp and then try a new fuse. If it still blows you have the power wire grounding out somewhere, if it doesn't then it would have to be the amp.
Apr 01, 2009 | Diamond Audio D5-600.1 Car Audio Amplifier
Blowing fuses
Are you sure you don't have the positive and negative power wires reversed?
Does the fuse blow without remote voltage applied?
Nov 09, 2008 | Jensen JPA285 Car Audio Amplifier
I have just recently installed a cd player in my 1990 Mitsubishi Triton dual cab. i couldn't find a constant power source so i took the clock out and used its constant power it was working for a week but...
okay u will have to start all over..with the istall...it is best that u pick up a afermarket wire harnest ...and that wiill help u alot ..make sure that u remove the radio and connections ...replace all bad fuse from the fuse box....make sure work's the clock and interior light....u need a good ground with the black wire ...u must have a good batter 12v with the yellow wire...and a good 12v Igniton red wire.
May 05, 2008 | Car Audio & Video
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
AudioBahn A2002T Car Audio Amplifier Logo
143 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
