Question about Pentax Optio 555 Digital Camera
Spring visible through the lens
I dropped my Optio 555 with the lens in the open position. When I tried to turn it off, the lens was stuck in the extended position. After several tries, it finally retracted, but the lens cover was stuck open. The camera then was locked in the starting position and the lens would not extend after multiple trys. When the on button is pushed, it will beep, the interior lens opens and in less than one second, after failing to extend the telescopic lens, shuts down.
I repair VCR's, DVD players, etc., and have also worked on some digital cameras, so I am not a novice, but on the other hand, am not familiar with the internal workings of this model. When the external ring surrounding the lens is popped off, there are 3 tiny springs that control rotation of the ring. They are responsible for closing the shutter when the camera is shut down. One of the tiny posts that hold the end of one of the springs was broken off. I successfully (and very carefully, I might add) managed to "cold-weld" the end of the spring to the area of the broken off post. I thought my problem was over, but now I notice that the large spring inside the lens is loose and flopping around. It is the spring that compresses when the lens retracts after being shut off. It is fine when the camera is shut off, but when turned on and the lens extends again, the spring inside is loose and flops in front of the focal area.
My question is, does anyone know the sequence for removing the lens from the camera so I can get to the spring??
Thanks
  • 538 Answers
Defective Lens Block.
Needs to be replaced.
Posted on Mar 20, 2009
Camera dropped. lens is stuck in open position, won't turn on
Hello
Thank you for using FixYa for your problem
Zoom lens is jammed, It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Jan 20, 2010 | Cameras
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Optio s4i shutter lock up
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken and needs to be sent in for proffessional service.
Sep 28, 2008 | Pentax Optio S4i Digital Camera
Optio M40 turns itself off and the lens wont retract into the camera when off
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
Apr 28, 2008 | Pentax Optio M40 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
I think my camera's stuck
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
May 16, 2007 | Pentax Optio M10 Digital Camera
Optio S5i Stuck Lens
Hi: First of all, with that behavior, your lens are stuck. Probably the problem was on the assembly. Try to disassemble and assemble them again. Regards
May 16, 2006 | Pentax Optio S5i Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio 555 Digital Camera Logo
143 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
