Question about Troy Bilt 5.5hp Self Propelled Mower
Husband says thinks it is starter cable has stretched and needs new one...does this sound correct and how to install it on Troybilt self-propelled push mower?
    Novelist:
    Champion:
  • 222 Answers
I'd love to help you, but I think you need to rephrase your question. There is no "Starter Cable" on this mower. Sorry.
James
Posted on May 27, 2011
  • James Burton
    James Burton Jun 04, 2011
    After looking at this question once again, I'm thinking perhaps you mean the starter "Rope"? It is not hard to replace. There are many videos on Youtube on how to perform this task, as it is a bit tricky the first time you do one. Here's a link to a very simple one for you:http://tinyurl.com/3s3jhhn
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How do I install the self propelled cable
Please try asking your question again, but add the MAKE and MODEL. There are many trimmers on the market and you're hoping that people guess the make and model you have. Thank you
Apr 28, 2016 | Garden
Troy-bilt self-propelled won't engage drive
Make sure the drive belt that turns the wheels is in good working order as well. It may have detached.
May 02, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Hi, I have a JS63C self propelled push mower that is having trouble with the self proppelled device. At the first speed 1 you can feel some self propell. However, if you advance to speed 2 or speed 3 you...
Hi Jerry. Sounds like your transmission cable needs to be adjusted. Since 1st gear is easiest for it to move in, you probably have little pressure on the clutch. Take the cover off the back of the mower (Torx T25 or T30 can't remember at the moment.) The spring on the cable should be measured when relaxed (handle not being held) then when you squeeze the S/P handle, it should stretch the spring 10mm. A friend or a clamp will make holding the handle and measuring more simple. Adjust the bracket the cable clips into in front of the tranny to obtain the desired 10mm, and you should be under power again.
Jun 03, 2011 | John Deere Garden
I have a TroyBilt series 560 self propelled mower with a Honda engine. The other day I was half finished with the lawn, stopped for a minute, and went to start the mower put my starter string was still...
hi there
csimonis
it is quite likly that you could need a new pulley and spring
but remove the cover and the starter assy 1st and check that the pawls have not stayed out or jammed , then try winding the spring and pulley up in the direction that the cord is moving when you pull the starter cord - check that end of the spring is still engaged onto the pulley , but if no tension is noted broken spring indicated
sometimes a replacement starter assy is quicker , cheaper
your local mower shop may have a spring & or pawls or starter assy for your model
but just in case get the model codes & numbers off the white tag from your mower
and check out this site for parts
www.ereplacementparts.com
go to troybilt
then select troybilt mower parts
then find your model from the list
then find starter assembly
parts can be ordered on line
cheers paul46
hope it helps
May 28, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How do you adjust the drive cable on a troybilt self pro pelled md# 12A-446A711?????
Unfortunately, you cannot adjust it. If you have an extra space to move it lower than it was on the handle you can do that. You might have to get a new cable. Or the belt may need to be replaced. Do you hear a grinding noise when you try to engage the self propel? If so the transmission may have gone out. The most common problem is that the belt has jumped off from where it needs to be and it is no longer turning. To check to see if the belt is off, you will need to put the mower on its' side, the side with the oil level check is the correct one. You will need to loosen the cover over the drive belt. This is done by loosening one or two bolts that hold it in place.The bolts should have 3/8 hex heads. You may have to maneuver the cover a bit to see if the belt is in place. If the belt has jumped above the pulley for the self propel then you will have to install a new belt.
Mar 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt 6.5 wont start without some help
Check to see of where the canles connect to the linkage, there are usually thumb nuts you can adjust similiar to that of the brakes on a bicycle handle bar.
May 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
