Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
I have a poulan/Weed-Eater blower GB120 if you pull the starter rope it doesn't have any spark. but if you spin it with an electric drill it fires great. i've tried putting a mag off of a poulan/ weed-eater lawn trimmer that is working on it and it still won't spark when i pull the starter rope. are the mag's interchangble. and why does it spark good when i spin it with an electric drill.
  • 2,510 Answers
Try a now spark plug first. If it is still hard to start then it is probably because of low compression due to worn rings and these need to be replaced.
Posted on May 22, 2011
    Sergeant:
  • 458 Answers
It sparks good with the drill spinning it because it generates a higher voltage. Try replacing the points and condenser.
Posted on Mar 13, 2015
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
How can I check to see if my fl1500 weed eater blower is getting fire
Pull the spark plug boot off, hold it near the block or another metallic surface and pull the starter (all of this needs to happen in a darkened room). If you see a spark, you know that it's getting spark.
Aug 29, 2011 | Poulan Featherlite Gas Blower, with Low...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Poulan rope broke and pulled out of unit. How is
I have manually fixed these starters before and it is really more trouble than it is worth (and not one unit I fixed ever worked exactly the same afterwards). I would suggest taking it to your local small engine repair shop. They have both the patience and the tools to do the job right and the cost is well worth it--trust me!
Oct 20, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Mar 23, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
541 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
