Tv powers up but remote has no effect on it (remote will only turn power on and off
  • 13 more comments
  • Gerry 6465 Aug 15, 2008
    teac tv model ctw3250s will not start up.
    hissing sound from speakers
    power switch seems ok.
    remote control will switch power on and off but will not perform other functions
    teac ctw3250s television
    when the set is switched on the filament on the crt do not glow like my other teac set
  • Gerry 6465 Aug 16, 2008
    teac ctw3250s switches on via front panel controls
    Does not respond to any other inputs from the front panel
    according to user manual tv should be able to be controlled by the front panel push buttons
    is there any way to check the tuner card
    It appears that there is no power in some of the tv
    There is no chance of getting the menu program
    to appear on the screen
    Teac ctw3250s does not appear to have any
    solonoids anywhere on the circuit board
    When the power is on the filiments ont the crt do not glow as with other sets ive seen
    Is it possible that the flyback is u.s.
    I have a good knowledge of electronics I was looking for some alternative thoughts on the problem
    There is no arcing nor ozone smell from the flyback
    i checked the cap in the power supply with a cap meter it was ok within specs
    There is a mech ticking sound from the speakers so i may have to check a lot more caps
    The remote has been cleaned and operating directly from a small variable power supply with a dvm monitoring the current draw
    the tv cannot be operated manually from the front controls
    maybe the tuner is U/S
    I have heard that lightning strikes to the antena can damage the sets eprom rendering all system down
    tvs can operate independant of the remote control
    but this one does not
    problem still exists
    looks like the set may have to go to the service centre
    There is no picture and no sound apart from a slow ticking sound
    I was interested if anyone else had experienced the same problems with a tv that I am experiencing
    Genius:
  • 1,011 Answers
Dear,
tv front panels have theres kind of problem, if u use it rearly.
so tv panel buttons should be used oftenly.
check your tv for dedusting. if it has
regards,
Posted on Aug 16, 2008
  • 1 more comment
  • SALMAN NASEER Aug 16, 2008
    dear,
    the easiest way to check all remote buttons is here
    just open the camera of ur mobile phone or any other digital display camera.
    place your sensor (IRLED) of remote infront of the camera so that u can see the sensor from ur camera.
    just press each button one by one and u will see light emitting from that sensor in your camera.
    if all button emitt light then it is confirmed that remote is ok, the problem is in tv reciever (Photodiode or phototransistor).
    but see the light intensity. is it glowing high or low.
    if low then u have to change the battery.
    regards,
    dear,
    did u find any faulty or blackish component inside..
    especially you have to check the capacitor, main filteration capacitor that is placed near the fuse ..
    moreover, u have to check if there is sound coming from flyback.
    regards,
    opening and checking keenly the tvs has a risky job. if u have done it before then u should check it . if not then its very risky to get involve deeply in that. its a work of perfect/experienced technician.
    keep these things in mind dear.
    regards,
  • 10,594 Answers
Hi Gerry-6465,
If you are non-tech person and don't know how to fix TV, it would be nice to call a repairman or take TV to local repair shop. being a tv repairman, I know that TV has high voltage risk inside and I will not advise you to open it or try to fix it by yourself. Safety is more important then any thing else. Hope you consider my advise.
  • Shahid Electronics
    Shahid Electronics Aug 16, 2008
    Its great Gerry-6465 that you have good knowledge in electronics. Nice to know.
    Hello Gerry-6465, Thats what I advised you earlier.
    Comment by Gerry 6465, posted on Aug 16, 2008
    looks like the set may have to go to the service centre "
  • 185 Answers
U may have problem in ur television board,try to solve it by call ur tv service engineer.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
What it was was a fauty RC solinoid for the standby mode, It kept flicking on and of repeatedly, so quick that the picture didn't dop out but it did interfier with the sound and picture quality (and made a very anoyin clik clik noise) I recomend removing and replacing the solinoid unit which is located on the secondary circut board at the back behind the main board to the left viewing it from behind. What I did was remove the solinoid, pry open the case from the top and inserted a small piece of NON CONDUCTIVE plastic to fix the switch to ON ie coper to coper, that way you can no longer switch the set on/off with the remote but every thing else works fine eg vol, picture mode, chanell select, ect.
thanks
good luck
Posted on Aug 15, 2008
  • 876 Answers
I believe that these are good quality televisions. You can probably get a universal remote that will work, but you might try a couple of things.
Did this problem just begin? Sometimes the remote can become accidentally deprogrammed. What sort of service do you have Direct TV? Cable? Do you have your setup manual? See if you can get a set up menu on the screen manually and if you can choose setup remote and go from there.
Sometimes just pushing the wrong button on the remote can create problems. I suppose you have already tried esc/exit/etc.etc. on the remote.
Here is the site where you might be able to get help from the company or a replacement remote.
http://www.teac.com/support/contact/
Good luck to you.
  • 1,800 Answers
If u cant change chanzis from the tv u goy to change ur tuner card
if u have an universal remote try to use with tht u can assure that ur tunoer car is gone
rate me follow me^^
    Master:
  • 521 Answers
Only two things can cause this problem.
1)either the remote is faulty or there is some moisture on the remote circuit board which hangs some functions for some time till the remote circuit is dried completely.
2)the second possibility is the faulty tv tuner card.
Better try to rule out the first possibility by drying ur remote with a hot air dryer if it doesnot work replace the remote n check.
thanks.
  • tech expert12 Aug 15, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • 1,031 Answers
Since the main problem is with your tv remote control clean the battery contact on the remote control panel ,change the battery if possible,may be its not getting enough power from the battery
    Master:
  • 382 Answers
Well i dont think batteries are your problem..If your sure then try to open the remote and check if the buttons of the remote are in contact with the circuit ,if it dint help then get a new remote..Thank you...
    Brigadier General:
  • 6,966 Answers
This could be indicative of a front panel control/button that is stuck in place or in the remote itself. Pls check both for any buttons that may be out of normal position.
Incidentally, perhaps it may be to your advantage to post back the brand and model of your TV.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Aug 15, 2008
    The safest os to seek the services of a qualified professional. If however, you are considering a DIY (do-it-yourself), pls be reminded that this then would require familiarity with electronic components & circuitry, use of a DVM and a soldering iron. Access to a service manual or at the very least a schematic diagram with voltage readings is a must.
    To your concern:
    • No video display, hissing sound. From the speakers or from the back of the TV?
    • If from the speakers, audio section is good, power supply probably partially good, probable fault video/horizontal/vertical sections.
    • If from the rear of the TV, then that would be your Flyback Transformer arcing, any ozone smell?
    • Incidentally, is there a mechanical ticking sound as well? If yes pls likewise check/replace 4700uF/16V capacitor near the heatsink.
    If you are somewhere in Australia, you may want to consult GOCompany, phone (07) 3846 5666, fax (07) 3846 4701 for more assistance or parts availability.
  • 19,396 Answers
Try replacing remote batteries first.
  • 5 more comments
  • Ginko
    Ginko Aug 15, 2008
    Try replacing remote batteries first.If this does not work ensure that there is no object between remote and tv control panel.
    Try also unplugging TV power cord for few minutes.
    If this still does not work the remote is faulty, here you can get a replacement.
    Replacement Remotes
    Universal Remotes controls
  • Ginko
    Ginko Aug 15, 2008
    Well "teac tv model ctw3250s will not start up.
    hissing sound from speakers" it is not a faulty remote. The tv does not start up at all, this is a faulty tv set.
    Probably a faulty IC (jungle IC for example) or a capacitor or a different component on TV main pcb board.
    You need a technician to fix this.
    from first explanation I thought your remote was just not switching channels.
    Call the number at the end of your manual to find out where to repair your TV, or ask a quote to a local repair shop.
  • Ginko
    Ginko Aug 15, 2008
    Do you have picture on your TV when you say it switch on? If it just light the led is not switching on.
    If you get picture but no other functions it is probably a front control panel pcb faulty.
  • Ginko
    Ginko Aug 15, 2008
    Hissing noise and no picture on a tube TV means a faulty ballast, this is a job that cannot be fixed at home by the user.
    If you want to fix your TV you will have to take it to a TV repair shop.
  • Ginko
    Ginko Aug 16, 2008
    If you need service you can call the number at the end of your manual.
  • Ginko
    Ginko Aug 16, 2008
    Can you get picture or not? If you do not get picture it is not the remote. If you get picture and does not change channels it is more likely the control panel than the remote.
    Please tell us is picture is coming on your TV set or not.
    Thanks.
  • Ginko
    Ginko Aug 16, 2008
    If there is no picture it is not a remote problem, apart experiencing same problem on own tvs, there are a couple of engineers around here that experienced the problem many times on someone else's tv. The remote is just putting the tv in stand by mode, the tv has an internal safety switch that keeps tv off as it recognises an internal problem , the typical clicking noise is the safety switch keeping your TV set off.
    Remote has got nothing to do with this.
    Probably it is not even a problem with tv controls, any burnt component on tv board will cause same phenomenon you are experiencing.
    Genius:
  • 1,847 Answers
You mean you are not able to change channel with the remote?
  • Legin Varghese
    Legin Varghese Aug 15, 2008
    check manually can you change the channels.
    of not the tuner card has gone bad.
    if yes open the remote and clean the circuit board with little alcohol and then try.
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Mag LCD TV MA-32EF1AC has power but won't turn on with remote or with power button on side of tv screen
If neither the remote nor the tv power button has any effect then it is safe to say that you may have an issue with the power supply section of your set.
Jun 22, 2016 | Televison & Video
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
JVC LT-32N310a screen locked
Most of the universal remote controls will not work with all the functions to TV, whatever the brand they be. It will be best buy an original remote control. Contact the Authorized service centre for JVC to get an original one.
Jul 05, 2013 | Televison & Video
I have a 20" flat
bad luck :(, problems is with the motherboard power circuit no option you need a repair sorry
Jan 31, 2011 | Philips Televison & Video
My GE tvwon't turn on with tv button or remote-just clicks
Most likely there is a problem in the power supply circuit inside the set. This probably would not be cost effective to repair. Thanks
Oct 21, 2009 | GE 13GP344 13" TV
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
