Satillite C630 boots to say "Boot Manager is Missing". Tried to start with recovery disk but loaded first disk and then screen went blank
  • 53 Answers
The startup of windows has been corrupted due to a virus or other operating system errors. You will need to reinstall the operating system and start from scratch.
Beware This Method ERASES everything on your computer.
Posted on May 22, 2011
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
Mar 26, 2013 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
Aug 31, 2012 | Computers & Internet
My Studio 1535 has crashed. It will not reboot Vista. When I turn it on it will show the Dell Splash Screen and then go to the "Windows Error Recovery" screen which shows these options:...
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 23, 2011 | Dell Studio 1535 Notebook
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
Ntldr is compressed
An NTLDR is compressed error is pretty easy to fix(much better then NTLDR is missing errors!).
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Feb 25, 2010 | Microsoft Windows XP Home Edition
Boot manager is missing and wont load windows 7 on compaq presario c700, no matter what i do it keeps returning to the boot manager missing press ctl alt dlt.screen how do i fix it
If your using a DVD to install the operating system, it could be either dirty (just needs a wipe) or the files on the disk are corrupt.
If you are getting this error while Windows 7 is starting up perhaps you can try doing a "repair". Boot off the DVD do a repair (not from the recovery console) and see if this helps.
Hope this helps.
Nov 08, 2009 | Compaq Presario 700 470024-192 Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
David Payne
David Payne
