Question about Casio FX-115ES Scientific Calculator
Convert from polar to rectangular & vise versa using calculator with RCL&POL GIVE EXAMPLE JUST PROCEDURE THANKS 9
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Examples #036 and #037 in the Appendix illustrate how to convert between polar and rectangular coordinates. If you need the appendix and/or the manual, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
Posted on May 22, 2011
How to covert from polar to Rectangular
Let use an example to convert from polar to rectangular. There may be other ways to do it on this particular calculator, but this should work on all calculators.
Let's use 20 degrees and 5 units for our polar.
Sin 20 degrees = y/5, cross multiplying we get y = 5 sin 20 degrees.
Similarly, Cos 20 degrees = x/5. Cross multiplying we get x = 5 cos 20 degrees.
Thus, I get (1.71, 4.70) as the rectangular coordinates of the point.
Good luck.
Paul
Nov 06, 2015 | Canon F-603 Calculator
How to use pol ?
The Pol function converts coordinates from rectangular to polar. Pol(x,y) converts the rectangular coordinates (x,y) to polar coordinates (r, theta).
For examples and instructions, see page E-37 of the manual and example #036 in the Appendix.
Dec 07, 2012 | Casio FX-115ES Scientific Calculator
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Apr 19, 2012 | Casio Algebra FX 2.0 Calculator
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
I've read that the Casio fx-115ES does a great job working with complex numbers, but I haven't found it to be so simple. I am looking for an easy way to convert from rectangular to polar form and back. It...
You can perform coordinate conversions in the COMP, STAT, MATRIX and VECTOR Modes.
Angle unit may be in either degree or radian.
To convert from rectangular to polar, (SQRT(2)/2,SQRT(2)/2)
Press [SHIFT] [+] (Pol)
Screen displays Pol(
Type in SQRT2
Use right arrow to move cursor out of radical
Type in /2 [SHIFT] [,]
Type in SQRT2
Type in /2
Close the right parenthesis
Screen displays Pol (SQRT2 /2, SQRT2 / 2)
Press [=]. Display echoes the command on top line and result in bottom line as r=1, theta =45, (if unit is in degree) or theta = 0.7853981634 if unit is radian.
To convert from polar to rectangular coordinates
Note: You cannot use the answer memory to convert back to rectangular because the calculator will use the r-value only. So you will have to enter the radius AND the angle.
ex: Rec(1,45)
Angle must be in degree
Press [SHIFT][-] (Rec)
Screen display Rec(
Type in 1 [SHIFT] (,) 45 [)] [=]
Calculator displays X=0.7071067812, Y=0.7071067812
If you press the SD key hoping to convert the decimals to radicals, the calculator will not do it.
As to the "confusion", I have found none.
After you finish entering the argument of a square root, use the right arrow to move cursor out of under the root symbol to signify that the argument is complete. If you use a left parenthesis inside the root, you must insert the matching right parenthesis inside the root, then move cursor outside the root.
This is how the calculator behaves, and I am not expressing an opinion on how simple or complicated that is. I assume that to make full use of the calculator capabilities, one has to converse with it, using the syntax it understands.
Mar 31, 2010 | Casio FX-115ES Scientific Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Canverying polar to rectangular
Here are exemples from the manual.
May 03, 2009 | Casio FX-300MS Calculator
Polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Dec 02, 2008 | Texas Instruments TI-86 Calculator
Casio FX-115ES Scientific Calculator Logo
368 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
