Question about HP LaserJet M3035 MFP Printer
HP LJ M 3035 Printer does not detect printer ink cartridge
  • HP Master
  • 1,915 Answers
Is this a new cartridge you have installed that does not work? Or did a previously working cartridge suddenly stop. If you just put in a new cartridge, put the old one back in to confirm whether the issue is the printer or the cartridge. Did anything odd like a paper jam happen just before this started. If so, there might be some paper bits blocking a sensor or a contact might be damaged.
Posted on May 22, 2011
Hp 6515 cartridge shows low after a refill
There is no such mechanism to detect ink levels in your printer., it wont detect if adding more ink in it., it will detect only new cartridge when you replace it., printer shows estimated ink levels as per the print outs. This is hp trick to aviod refill &non hp consumables...
Sep 30, 2014 | HP Photosmart 6515 Wireless Color All In...
I have put a tesco hp compatible ink cartridge in my hp 2050 deskjet printer but a msg comes up INCOMPATIBLE INK CARTRIDGES The cartridges listed above are not intended for use in this printer as...
This model Cprinter may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 26, 2013 | HP Deskjet 2050 All-in-One Printer
Hp laserjet p3005n 55.04.92 dc controller error
I need help,my printer are hp lj 3035,the error is 55.04.92-DC CONTROLLER ERROR,how to fix this erroer?
Feb 21, 2012 | HP Hewlett Packard LaserJet P3005n Printer
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
10.94.00 error remove shipping lock in hp lj 4515 printer
Open the ink cartridge cover and remove the paper or plastic shipping retainer on the bar holding the ink cartridges in place. If the ink cartridges are pre installed, lift them out and check that the plastic tape is removed from the gold contact and print head.
Apr 15, 2011 | Office Equipment & Supplies
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
HP LJ p3005 dn printer will not recogonize hp print cartridge.
you may use a non genuine toner cartridge, check another working cartridge
Mar 30, 2010 | HP LaserJet P3005dn Printer
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
Sep 03, 2008 | HP Officejet 4355 All-In-One InkJet...
Hp Lj 2430TN Printer
We ran into this problem a lot when this series first came out. There is a simple sensor on the left hand side of the toner cartridge area inside the printer that physically detects that a toner is installed (or not). With the left cover off, there is a plastic bracket that holds a lever; unless it is not, then it tells you that you have no toner installed. Lame.
Jan 16, 2008 | HP LaserJet 2430dtn Printer
HP LaserJet M3035 MFP Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
