Question about Sewing Machines
The thread keeps breaking, I can't seem to get the right tention, so i need help. thank you
  • referee1 Jun 01, 2011
    thread is still bteaking
  • 48 Answers
Hello! It sound to me like your needle is dull or old. Old needles get sharpened by the miles of thread that is fed through them and as the needle reverse in direction and begins to head back up it will actually cut the thread instead of allowing it to slide through. If you change the needle and the problem persists you may have a timing issue.
Good Luck!
Chris
glfi.com
Posted on May 23, 2011
  • referee1 May 25, 2011
    I ALREADY CHANGED THE NEEDLE
I am quilting and the thread keeps breaking. What is the problem?
Not sure if you are piecing or trying to free motion quilt. If FMQ, try using an Embroidery needle (it has a groove in the shaft that helps protect the thread) or a Topstitch needle. Make sure the thread is not too thick for the needle's eye. Check to make sure the upper and lower tensions are not too tight. You might try changing brand/type of thread.
Here's a needle guide:
SCHMETZ Household Needle Chart
Or review suggestions for breaking thread here:
Why is my thread breaking
Hope this helps!
May 20, 2015 | Sewing Machines
My thread keep breaking no matter what kind of thread I use its something to do with the tension but nothing I do seems to fix it. I'm in the middle of a big Christmas project I need help fast I'll...
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 21, 2012 | Sewing Machines
Thread keeps breaking
check to see if there are any burrs in that area
May 24, 2012 | Husqvarna Sewing Machines
Thread keeps breaking, can't seem to get the
1. Maybe you are using the wrong size machine needle or poor quality thread.
2. You must always lift the presser foot before threading the machine to release the tension discs.
3. Maybe you have broken thread stuck in the discs or bobbin race. Give them a clean. Pull a thicker thread by hand through the tension discs when the presser foot is up.
Jun 01, 2011 | White Sewing Sewing Machines
Model vx710 upper tread keeps breaking adjusted both tentions
If the timing is a bit off this could also be causing the thread to break. lf you've had a good attempt at getting the two tensions right and not having any joy, then it could be timing is just out a little.
I'm assuming that its good quality thread and same top and bottom and that you've checked the thread paths for any places where it could be catching/jamming etc already.
If machine has been at least 2 years since a service then might be time to take it for one.
Apr 27, 2011 | Brother Sewing Machines
I have a memory craft 1001 I have a problem with the thread breaking, what am I doing incorrect?
may not have it threaded into the tention dial right needle may be in backwards or could have bur on bobbin case or bobbin or it may be your thread. hope this helps
Aug 18, 2010 | Janome Sewing Machines
Tention and wrong thred, also use jersey ball point needles 80/12 wcbotha@yahoo.com
May 12, 2010 | Tacsew 950
My thread keeps breaking. I got this machine
Thred breaking is one of the following: tention to tight, wrong thred, wrong needles - use jersey baal point 80/12 needles for all material and thred, bobbin tention too tight. wcbotha@yahoo.com
May 10, 2010 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
