Question about Whirlpool AKZ159IX Oven
I have a Whirlpool built in oven AKZ 161/03/1X The top oven is both a conventional oven and a grill. The oven is working and heat comes off the element when it is turned on, however if the grill is turned on the element does not heat up . Can you please advise. Thank-you
  • 157 Answers
SOURCE: AKZ 451 will not heat up
element,make sure clock is set though
Posted on Jun 30, 2009
barkencoa
  • 3463 Answers
SOURCE: Whirlpool AKZ 446 Electric fan starts but oven
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
Posted on Dec 29, 2009
Suthrnbelle9
  • 31 Answers
SOURCE: Manual for whirlpool oven model
I do believe this is not the correct Model number - if you send me a little more info I can help you along further
Posted on Nov 03, 2010
  • 250 Answers
SOURCE: When the oven is turned on the lights and fan
Sounds like the element, its thermal fuse, or relay/contactor is not functioning. You should check those, or have a professional do it if you're not comfortable with that.
Posted on Dec 02, 2010
blackmar
  • 235 Answers
SOURCE: We own a Bosch (Built-in) oven HBN4305.0B and the
With the power turned off it is usually a case of, in most ovens, just removing the element by unscrewing two screws. Unclip the wiring and make a note of what wires go where. Find a new one and install in reverse procedure.
Posted on Feb 11, 2011
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
NEW WORLD - NW601FP Electric Oven
i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Jan 17, 2012 | New World Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Whirlpool AKZ 446 Electric fan starts but oven does not heat up ?? Is the element easy to replace/fit? Thanks
Good luck..
Dec 29, 2009 | Whirlpool AKZ159IX Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Jun 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Sep 27, 2006 | Whirlpool GBS277PD Electric Single Oven
Whirlpool AKZ159IX Oven Logo
59 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
