Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman 42 inch 917.257661 mower, having transmissions issues. Loss of power and having trouble getting into forward. No problems in reverse. It almost seems to be backwards.......drive belt appears to be on right. This happened after replacing drive belt. Any help would be appreciated.....Thanks Jim
Nick_Savage
  • 45 Answers
SOURCE: Craftsman 42" 19.5hp B&S Stalling
Check to see if all of the belts are in-tact. A belt may have become stressed and out of proportion from sitting for such a long time.
Posted on Jan 04, 2009
SOURCE: Need diagram of deck linkage on Craftsman 42 inch
Go to sears parts direct and punch in your model #
Posted on Mar 27, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
I have a craftsman lt 7100. It wont go forward or backward. today I changed the drive belt and same problem
Sounds like trans locked up if the mower is older it can be replaced I found one for my MTD 42 inch on Craig's list in my area.
Apr 19, 2018 | Craftsman Garden
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
What is the size of the belt on a craftsman Lt1000 21 horse Briggs and Stratton 42 inch deck
do not just buy a belt that is "close" to your size belt. the size of the belt is not always a standard size, there is a width as well as a length and also a power rating , that is critical in belt replacement. you must have the model number of the Mower unit "not the engine model" to get the correct belt. OEM belts are made to certain specifications to withstand certain actions of the mower and the wrong size belt could result in a dangerous situation of the blade not stopping or engaging sporadically, or if it is a transmission belt , the mower may not go forward or not stop moving which again is dangerous.
Mar 05, 2015 | Craftsman Garden
New tractor power loss on a grade, deos not develop full speed
Hello Joe
If you have an automatic or hydrostatic transmission then you have a lemon, which means once the oil heats up in your transmission it thins out and clutchs and swash plate have no grip on the drive system which is hydraulic pressure needed to hold on the shaft and axles this happens all inside the transmission you cant see it but you can tell when going up slight hills and when you have the blades engaged it crawls like a turtle get you warranty out Joe..... dont touch anything that may void your warranty..... just call service department they will send service man out to your home even after that keep a good eye on your tractor since its still under waranty for further problems.
Joe your 20 year old craftsman had a better built ****** by sears and you probably had a 6 speed or five speed even hydostatics were good too,they dont have much problems except belt slipping its an easy fix this new tractor u need service man right away.
Joe
Oct 08, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Mower has difficult time moving forward
Is the mower blades engaged if so check spindels if not check the transmisson but check all pulleys first
Sep 23, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 42 inch craftman riding mower when i let out the clutch it stalls and another problem is that it wont turn over unless i jumo it it has a brand new battery and new selinoid
there are several safety switches which are all tied into a central relay which defeats the starting and kills the running, unless they are all in the correct safe running position. a lot of craftsman mowers have that same exact let out the clutch problem and it is related to a failure in one of those parts.once you get that issue resolved, the other issue may resolve itself.
May 19, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hydrostatic Transmission Failure
There is a transmission bypass lever on the back of the mower, if the bypass is moved out of the drive position, it will not drive in either direction, and will be really easy to push.
May 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
