Question about Mitsubishi Televison & Video
I have a Mitsubishi CS-40509 TV. It is over 12 years old. Recently, there is at least a 30 second delay before the tv responds to the remote control/control panel commands. If i turn it on, the green light doesn't light up right away and about half a minute later, it turns on. When I turn it off, the picture goes off but the green light stays lit for 30 secs then goes out. Whenever I press the input button, it does not change right away, if at all. This has never happened during all the years we had the tv. Any ideas on what this problem is and how to fix it? The picture and audio are fine.
    Novelist:
  • 123 Answers
After 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 12yrs old itseems TV TUBE is still in good condition because you have said that when display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
Posted on May 22, 2011
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
Mitsubishi CS40509
Opeen the back panel of the tv,
near the coil you would see 6 potentometeres, (small turnng things) one is written vhold and and the other horizontal scroll, adjust these to set the picture,, Be careful nt to eletricute your self..
IF THAT FAILS THE PICTURE GETTING WIDER AND SMALLER CAN BE CAUSED BY EIGHTER THE COIL, HORISONTAL CIRCUIT OR VERTICAL CERCUIT.. most often its just a capicator.
Jan 10, 2008 | Mitsubishi CS-40509 40" TV
Manual for cs-40509
Thus, being honest to be able to Timberland Boots(http://www.shoestimberlandstore.com). No less than they will observed suit to be able to fantasy upwards this kind of reply. Netherlands and also Barrett, held simply by large US ALL nutritional pharma business, NYBT, never have considered that crucial that you response in any way. Whilst Timberland Boots Men(http://www.shoestimberlandstore.com) carry out have got their particular makes use of, toothpaste and also tampons, Netherlands and also Barrett have got created a small business with the wishful thinking about nutritional supplements and also vitamin supplements.
http://www.shoestimberlandstore.com/
Jul 05, 2010 | Mitsubishi CS-40509 40" TV
Where may I buyt a Mitsubishi CS-32105 TV Remote? I have lost my remote.
Online. Just type in Mitsubishi CS-32105 TV Remote on your browser and bingo, many sales locations will appear.
Jul 24, 2009 | Mitsubishi CS-31205 TV
My tv is shows a blue screen. My tv does not respond to the function button's and there is a lock in the upper left hand corner of screen of JENSEN 27" tv
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation.
Please do leave a vote for the solution. Thanks for using FixYa
Jul 03, 2009 | Mitsubishi CS-26201 TV
Cs-36509 mitsubishi tv has a flicker.Makes it hard to read words. Is real bad when you first turn the tv on, but after a minute it settles down, but is still there all the time... any suggestions?
Yes first it may just be bad solder on the
flyback transformer , or the Picture in Picture
module has some bad caps . a fair shop
price is about 180-200 and it worth the repair
they are great TVs and are made to last.
ps i have repaired my mitsubishi once , and
its going strong. 18 years old .
THE OLD STUFF IS BETTER THEN THE NEW STUFF.
Mar 25, 2009 | Mitsubishi CS-36509 TV
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Same Mitsubishi as before. The CS-2657R
The cable box remote is programmable = contact your cable
provider to program to work volume on your Mits.............T.
Nov 28, 2007 | Mitsubishi CS-26201 TV
Televison & Video Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
