I have a Kenmore washer model 1102704602. I'm getting the LD - Long Drain error message. I've taken the drain pump off...looks clear to me. discharge pipe is clear as well. still getting "LD". is there a common place things get plugged? if something went over the top of the tub, how would one get to it to clear the object? Help.......kids need clean clothes. wife's stress meter is pegged.
  • 10,319 Answers
Most likely the pump that drains the washer is clogged up
It will need to be serviced by a qualified technician
Posted on May 22, 2011
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Washer is diplaying Ld and won't restart
Ld stands for long drain.
Here is what the manufacture says about that error, my comments will follow.
LONG DRAIN If the drain time exceeds eight minutes, Ld will be displayed, the water valves will turn off, and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be cleared and the machine will turn off after a maximum of eight minutes. Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the drain pump filter for foreign objects, and also make sure the hose from the tub to the pump is not plugged or kinked.
4. Check the electrical connections at the pump and make sure the pump is running.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments -----> This error is usually due to something getting stuck in the drain pump or drain hose, typically after washing a rug with a rubber backing that has come off or small articles like baby socks that were not put into a garment bag prior to washing.
To clean out the pump the machine would need disassembled and is best done by a service professional unless you are up for a good challenge.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I'm getting the LD message indicating that I'm having a drainage issue. I've taken the back off, inspected the hose and found nothing. The pump looks clear. I don't want to put it all back together...
make sure there is nothing in the hose the comes down from the tub to the drain pump.
there could also be something small in the drain pump that is slowing or stopping the impellar
make sure the connections are all in good order
Mar 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water not draining - "Ld" error message
Hello there:
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
NOTE: After
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Dec 25, 2009 | Kenmore Washing Machines
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Calypso top washer has an error of LD
LD is an error code indicating a “long drain”. If the water is not pumped out quick enough, you will get this error code. This model of washer has a revised pump/motor assembly that will improve the performance of pumping the water out. A poor pump out condition could also be caused by a failure of the drain check ball system. This is a chamber of the outer tub located on the lower rear section of the outer tub. If something gets lodged in the inlet or outlet port of the check ball chamber, you will have either a no drain condition or a poor drain condition. This would have to be checked to confirm.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
I have a a kenmore oasis ld error cod
ld error code is long drain some thimg clogged up pump ,, first check drain hose could be too far down and siphoning,, if not repl/ or cleaned out pump.....
Dec 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld and ob error codes
hello.........
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Error code LD
I had this problem also. Ld means that it is taking too long for the tub to drain, usually something is clogged. Try taking a shop vac and sucking out the drain hose that goes into the wall drain. This should at least get you where the tub will finish the cycle you have going. I tried this and it worked for about 2 loads then "Ld" again. Finally removed the drain pump from the washer and let it empty completely. So far this has worked.
Jun 10, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
