Question about American Bath Factory F6-5730-OC Lavatory P-Trap, Old World Copper
I am having a factory out of which smokes comes out in any case i want to dump smoke in water ..please tell about any machine in reference to that
My Ford Windstorm Has White Smoke Coming Out Of Exhaust,ConstanLy,Thick White smoke
White smoke is an indication of water in the exhaust. This can be from condensation in the muffler, but that type of smoke usually dissipates after a minute or two of running. Constant, thick white smoke is usually a sign of water leakage into the combustion chamber(s), either via a blown head gasket, cracked head, or cracked block.
Feb 08, 2016 | Ford Cars & Trucks
What could blue tailpipe smoke be from?
Your issue could be a few things. Simplest first would be the PVC valve. Other issue would be valve seals, valve guides or piton rings. The blue smoke is from your vehicle burning oil
May 19, 2014 | 1988 Toyota Supra
Vehicle was in side swipe accident left side--w/s replaced---after getting veh back from shop approx 3 weeks took veh thru car wash major water on both pass and driver frt floorboards and...
You can have a shop with an EVAP Smoke
Machine, use it to fill the cabin with smoke
& see if it comes out,then maybe decide
if water could enter that area
Jun 14, 2011 | 2003 Toyota Highlander
My heat stopped working my cars blowing smoke out of the muffler and my temperature gauge is past hot but the carrs engine isnt smoking
if theres smoke coming out of the exaust then the motor is smoking. sounds like you have a blown head gasket and it's low on water is why the heat isn't working.
Dec 27, 2009 | 1991 Ford Escort
Smokey volvo
Is there a question here ?
Are you refering to smoke coming out of the exaust ? Engine compartment ?
Please clairafy..
Thank you..
Aug 03, 2009 | 2003 Volvo S60
Oil level light/smoke from radiator overfill/sludge in same
If oil is Clean and there is no White Smoke that Disapates Fast, Check for Transmission Cooler (IN RADIATER) Problem
Feb 07, 2009 | 1996 Oldsmobile Aurora
White smoke
the white smoke is oil - did you overfill the oil ? if you tipped the machine your air filter could be full also - if this is an old machine it could be ready to throw a rod but not enough info from you to tell
Oct 26, 2008 | Toro Lawn Mower With Toro Power Tools
Black smoke
Change your air filter and clean the blow by tube that crosses the heads and connects to the back side of the air filter. If the tube or the air filter is clogged, then the oil that the blow by removes is going back into the cylinders, causing the black smoke. Also keep in mind that a Harley will blow a little black smoke upon starting as it ages, it's normal.
Jul 26, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
American Bath Factory F6-5730-OC Lavatory P-Trap, Old World Copper Logo
44 people viewed this question
Top American Bath Plumbing Experts
Donni Steen
Tom Chichester
Are you an American Bath Plumbing Expert? Answer questions, earn points and help others
