Question about Refrigerators
I have a frigidaire side by side model FRS26KW3AQ6 ref. the compressor tries to come on but does not seem to start i cleaned the condensor a week ago and it worked well for a week and now it is doing the same thing not starting all fans are working
  • Refrigerators Master
  • 2,128 Answers
If the compressor makes a clicking sound every couple of minutes you could have a bad start device located on the compressor.unplug the fridge,pop off the clip and slide the start device off of the compressor,the easiest way to check it is to just shake it,if it sounds like a piece is rattling around in it then it's cooked and needs to be replaced.part number 218721119 and it's around 40 to 50 dollars.
Posted on May 22, 2011
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
The ice is melting and the food in the frezer is
TRACK DOWN THE BUZZING. IT MAY BE THE COMPRESSOR TRYING TO START, MAKE SURE THE CONDENSOR UNDER THE REF. IS CLEAN AND THE FAN IS RUNNING
Jan 13, 2010 | Electrolux Refrigerators
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ref. side stops cooling intermittently. Replaced damper control but problem occurred again three weeks later.
HI,
The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
thanks,
May 19, 2009 | Frigidaire FRS23H7CS Side by Side...
GE PSC23NSD SS refrigerator malfunction
Check the cover in back of the freezer for for frost build-up. I think Frost reached the evap fan-blades and stopped it from blowing cold to the ref-side. Contro;s can be confusing. The ON-OFF controls how long the compressor runs, and the other dial how open or choked the airflow from the freezer into the refrigerator. Sometimes it happens that you have that flapper shut and no air is getting moved to the reefer. If frost is on the cover you have dead heater elements on the evap coils or a faulty hi-temp limit switch, which is the disc thingee at the top of the coils. A bad timer also may disallow it going into defrost - think about it. Chris in big bEar
Apr 20, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Freezer works but refrigerator is staying at 60 degrees
listen to hear if you can hear the evap.fan motor running.check to see if you have any frost built up on freezer back panel.if so you have a defrost problem.clean coils under ref. and make sure condensor fan motor is running,that is by the compressor.
Mar 06, 2009 | Frigidaire GLRS263ZD Side by Side...
No water no ice
Dear Customer
Please perform the following checks
Refrigerator starts and stops frequently :
Refrigerator or freezer is not cold enough :
Please rate this,Thank u
Dec 18, 2008 | GE GSS20IEP Side by Side Refrigerator
Not as cool
heat is normal, it appears that condensor is blocked with fluff, there are two versions of this product, one has a radiator ooking grill in the back anf the other has the same behinf the lower front plastic trim remove trim and clean with vacuum cleaner this will allow refrigerant gasses to cool more quickly. Regards Advisor
Aug 12, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
