Question about Karcher FactoryReconditioned K398MR 1750 PSI 15 GPM Electric Pressure W
My electric washer keeps cutting in and out when turned on, and when washing, the pump stays on but doesn't seem to have the pressure it should. Model K3.97 Thanks, Ross
    Problem Solver:
  • 11 Answers
Have you checked to ensure that there are no leaks from your hose or any of the connections?
Posted on May 22, 2011
Washing machine does not empty
see the causes and use the common sense, God bless you.
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a franklin electric 4
I have plenty of children and grandchildren, none with my name..... Cash is better but that is not what I'm doing this for.
Sounds like your system is "water-logged", shut off the pump, drain the bladder tank and check air pressure in the bladder. Set it to about two psi below the normal cut on point of the pressure switch. If that doesn't solve it, post again.
Sep 10, 2012 | Franklin Electric 1/2Hp 2-Wire 110 Vlt Sub...
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
I can hear the hot watre dripping into the washing machine when it is turned off
see this cause:
drain line clogged, +remove some sock with pliers maybe you can remove the agitator+pumps propeller defective.
frozen pulley pump, replace the pump
improve the drain line+if the drain line reach more 4 inches, cut of the excess. if is lower,install air/gap siphon break assembly.
God bless you
Jul 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
My washingmachine doesn't continue to the next phase of the program
Yes! it seems that the program controller unit is the suspect, but first you need to check with other set programs and see if the entire cycle goes through. If not this can be related to a processor gate failure to go into the next sequence.
Also check the water level sensor and the drain pump and push in all connectors to be fitting. MAke sure there is no moisture within or else you will need to use a dryer to clear off and check.
Jul 02, 2012 | Candy CBL160 Front Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
Washer is not spinning or draining it keeps flashing F21
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 24, 2011 | Kenmore HE2 Plus Front Load Washer
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
Karcher FactoryReconditioned  K398MR 1750 PSI 15 GPM Electric Pressure W Logo
696 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
