Question about Sunbeam JARDEN FoodSaver V3840 Upright Vacuum T000 18001 T000 18001
Hi I have the FoodSaver V3840 that's not doing a full vacuum. I live alone so know the unit wasn't abused. I use it everyday to prevent waste. I use the canister function and saw some moister residue in the hose but never had full fluid in either tray nor hose. I opened it up and everything seems intacked, didn't find any vacuum leaks. Thanxs, Mr. Kim A. Gonsalves
    Guru:
  • 1,833 Answers
One thing that you need to check first, whether anything stuck in the vacuum. Also contact FoodSaver customer support at " http://www.foodsaver.com/Index.aspx".
Posted on May 23, 2011
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
I have a Foodsaver 2840 that will vacuum and seal, but not seal alone. The manual button does not work (though it worked earlier today). I have tried everything. Any hints?
Hi donnaj615...
Start the vacuum and then immediately click on the seal button...
I have a 750 that does the same thing...
Please take time to rate me
Aug 13, 2011 | Tilia FoodSaver V2240
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
May 17, 2010 | Tilia FoodSaver V2240
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Feb 16, 2009 | Tilia Kitchen Appliances - Others
Sunbeam JARDEN FoodSaver V3840 Upright Vacuum T000 18001 T000 18001 Logo
402 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
