Question about Garden
I have a xtreme klean electric pressure cleaner model # xte1650. I've been out of commission for a while and when I tried to get it going it feels like the motor works but the pump seized. How do I get it lubricated for it to work again?
roniecon
  • 6927 Answers
SOURCE: electic window on mazda mx5 sticks when going
Look really good,for another window guide that is missing,or you may need to adjust the guide track,or the window channel,that the window sets in,If the window is moving around in the window channel,then the adhevsive has let go of the window.
Posted on Nov 06, 2009
Testimonial: "I will try that and let you know the outcome. Many thanks for your suggestion."
  • 760 Answers
SOURCE: On our electric pressure washer. Nolonger works.
Good guess. You can find parts at: www.pressure-washer-parts.com
They handle comet pumps. See if you can find the number on the pump. Not a bad brand of pump,but they do wear out. Never run pump dry, never let idle more than a couple of minutes, the water recirculates in pump and gets hot. Install a temp relief vavle when you rebuild.
Posted on Jul 19, 2010
  • 1388 Answers
SOURCE: My pressure washer starts fine, shoots water OK.
Your pressure washer may not have an ez-start valve installed from the factory. Without the ezstart valve, you will need to hold the trigger on the wand open to release the pressure to easily start your engine. This link will show you what an ezstart valve looks like. Ez-start valve is really not needed if you do not mind the extra effort to release pressure. Just more parts to go bad. Money well spent would be a method to easily inject oil or stabilizer into your pump when in storage. The oil/spabilizer will displace the water from within the pump and lubricate the internal parts and prevent freeze damage. Good luck
Posted on Sep 30, 2010
john224
  • 1378 Answers
SOURCE: Just opened pool for the
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Lubrication will not work at this point.
Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on May 12, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a model #919.167200 5hp, 20gal. air
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Posted on Jul 28, 2011
Testimonial: "Thanks for the help, thats what I needed to know was how to check what was faulty. The breaker still tripped so it must be the electric motor. Thanks"
How to remove linseed oil
scrape of as much as you can with a plastic scraper to min any damage. The use paint thineer to clean off the rest.
Jul 09, 2014 | Klean-Strip Klean Strip Boiled Linseed Oil...
Is klean strip adhesive remover okay to put on dry wall?
Yes-just let dry after-then on prep of wall after you may have to skim wall with a thin coat of drywall compound and sand smooth
Jan 23, 2014 | Klean-Strip Adhesive Remover Voc
Hi, I've got an Henry Hoover. I've got electric
TRY RUBBER GLOVE / IT WILL STOP ELECTRIC SHOCKS ,I AM A CLEANER AND IT WORKS FOR ME
Apr 09, 2013 | Vacuums
I received the Patton Electric Heater model number PUH682 for a Christmas gift. It worked fine for about one week then just about 3 days ago, when I went to unplug it, the plug and cord were just red...
I saw your post and I encourage you to report your problem to The U.S. Consumer Product Safety Commission. I called them to report the problem. The number to the company (Patton) is 763 444 8567. The number to The U.S. Consumer Product Safety Commission is 1-800-638-2772. The U.S. Consumer Product Safety Commission will take your report and if you know others that have this product and they have experienced the same thing encourage them to call and report it. The heater I had melted unto a ultility extention cord and was smoldering. It could have cause serious injury or damages to me and my family.
If this product could have injured you as well. The are a public hazard and need to be recalled.
Jan 04, 2011 | Patton PUH680-U Utility Heater
Very rough idle on my 97 SVX although It does not stall.
you know ...the only way of kleaning injector is to get-it to a garage and make it whit the pressure machine ...bit expenssive but real good ...no chemical can clean and unblock injector no mather what they say! those product can only keep them clean ...but im from those who bealive that less chemicals in a engine better it-is!
Jun 22, 2009 | 1992 Subaru SVX
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Fuel starvation
i have a 1985 k100rt and it would not start. i made some calls to bobs bmw in maryland and i unplugged electrical connector on gas tank ,sprayed it with electrical contact cleaner and coated it with dielectric gel. that fixed it. also check main grounding point on frame under gas tank.on a bike this old you need to make sure electrical connections are clean. the fuel pump is supposed to deliver fuel at 36 psi according to clymers repair manual. i hope this helped .
Nov 20, 2008 | 1988 BMW K 100 RT
Fuel starvation
Nov 10, 2008 | BMW K 100 RT Motorcycles
Xtreme Sound XB80
Go to http;//audio.manualsonline.com
May 24, 2008 | Xtreme Sound XB80 CD Changer
Garden Logo
556 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
