Question about Dell A215 Computer Speakers
Tag # 9ndwl31, we have no power, check the connection-connected no green light. no sound
  • 53 Answers
Replace the speakers. Seems like they have stopped functioning properly which is very common in dell speakers
Posted on May 22, 2011
Tag light out, bulb replacement did not work.
Follow wiring back checking as you go- It is NOT a independent hot. I believe its just a corroded or shorted connection in line.
Jan 04, 2014 | 2002 Kia Rio
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
The gauge lights and rear running lights tag light are not working
Did they go out together? or did you notice the gauge lights and possibly your tag light has been out? In any case start with the tag light, check your bulbs then using a test light( to make sure i always have ground i use a jumper wire connecting to the battery directly to test light) check for power at the middle of receptacle. when checking for power connect jumper to ground then test light or try to find a good ground somewhere in the rear. if no power check the wire behind the receptacle. I don't think they run of the same circuit but to be safe check for blown fuses first!
Feb 03, 2013 | 2005 Ford Taurus
No sound produced, but power green light is on but dim.
make sure you have a good ground contact, bolt connection to body and make sure to sand off paint where you are screwing ground connector.also check that you have good 12volt(power) & remote wire connection. if that is good check for a good connection with your rca jacks. with that you should get sound.
Apr 13, 2011 | Car Audio & Video
When is my battery charged, is it when the light flashes or when the light is solid green as i have lost the instructions
When you snap the Leapster into the charger, the green light should come on (solid green). When it has finished charging, the light should go out. I don't know why it would flash green aside from maybe a bad connection.
Hope this helps!
Mar 01, 2011 | LeapFrog ® Leapster®2 Recharging Station
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
I moved my computer. Hooked it back up and now the side speakers do not work. They power on but no sound . tried several connections. USB is plugged in and the green to green connection is in. checked all...
Hi
Please can you advise if you have 2 sound cards installed
You will know this by looking at the back of the computer, the sound card wil have 3 ports coloured Purple/Dark Green and Light green
Your speaker connection needs to go into the light green and will have a symbol above it like this ))(left arrow)
If there are 2 sets of ports then try one and if that fails try the other if there is only one plug your speaker conneciton into the light green port
Regards
Jan 31, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
Dell A215 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
