Question about Honeywell Heating & Cooling
My honeywell smartfit unit is displaying "F4" with a spanner on the left hand side. Can't find any information to indicate what the fault indicates.
  • 17,970 Answers
F4 code means that the control valve has jammed.
Posted on May 22, 2011
Jandy Legagy LRZ pool spa heater not Igniting at all?
F4 = bad igniter ... Has this heater worked in the past and just suddenly stopped? Look for a bad igniter.
Nov 25, 2012 | Pool & Spa
Reset service indicator on Fiat Bravo. Service has been done at 18000 miles but indicator still says service required.
Hello! 1... Switch ignition off...2... Press and hold down the left button next to the seat belt light...3... Switch ignition on...4... Keep the button held down until the display reads 0 and the 'spanner' symbol goes off...5. Switch ignition off...
Guru...Saailer
Nov 16, 2011 | Cars & Trucks
Ive currently got a honeywell smartfit thermostat control which is displaying F24 which ive been told means i need to replace the control panel, again!! ive already replaced it once not so long ago (approx...
There are other universal replacements but if it was me I would stick with the honeywell parts. I know they are more expensive but in your instance where you already have a problem that is causing the control panels to fail I'm afraid you would make it worse by using other then factory replacements.Thank you
May 17, 2011 | Honeywell Heating & Cooling
Hi, I have just changed the bateries of a Honewell CM67ng wireless thermostat. The display now flashes a "Id -" text on the left-hand side (where the temperature is normally indicated/set). I...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Honeywell Programmable Thermostat Heater
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
I have a honeywell smartfit but it keeps coming up with a F4 error
I had exactly the same problem. F4 code says the control valve has jammed --- but it hadn’t.
I ended up having to swap out the room controller and the base unit (I bought the pair since it was winter and I couldn’t ‘eff’ about)
On investigating (well, you have to don’t you?) I could find no obvious fault but did notice that a large electrolytic capacitor was across the actuator motor.
Since these things work by reversing the supply polarity to the motor to drive the actuator one way and the other it strikes me as strange that a polarity sensitive component, one that must be always connecter positive to positive, is used in the way that it is.
Bottom line, tough luck, mate. Replace the units.
Jul 30, 2008 | Honeywell Heating & Cooling
My clock on my honeywell smartfit has frozen now the system will not work is it repairable
Before replacing the unit try replacing the batteries. After you replace the batteries push the run program button and see if the system comes back to life:)
Jun 27, 2008 | Heating & Cooling
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
May 21, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
691 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
