My comuters left shift popped off and how can i fix it here at home
I have a 2005 Buick rainier. Today we pulled up at home and the gear shift button popped off and stoped In neutral. Now it won t move or start . what is going on and how do I fix it
I found this info for shift knob. Note the picture. After the shifter is off, maybe a spring loaded piece sticking up from shift rod, Push it down and shift it. I'm just posting this from memory, different vehicle. You can talk to your local autostore or service department at local dealership or local salvage yard or ebay for a new part.
Mar 16, 2016 | Buick Cars & Trucks
2003 rear right axle shaft broke would that stop my tranmistion from shifting back and forth?
Having a broken axle shaft will let the diff spin freely, allowing the transmission to spin with no resistance. Resistance/pressure is what causes your transmission to shift. No resistance/pressure means no shifting.
Nov 19, 2013 | Lincoln Town Car Cars & Trucks
My shift key is sticking any solutions
I would think that you spilled food or liquid on it. Assuming you have a standard keyboard. You just need to clean it. Unplug it (obviously), then take it apart by removing the screws on the back. Pop the button out and use a q-tip and some water to clean in and around it.
Dec 30, 2012 | HP Pavilion p6210f Desktop 26GHz 6GB...
I have a 2000 Ford Taurus. My wife left the radio running with the ignition off for a short while. Now the car won't turn over, won't start, won't jump. There is one click when trying to s
The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
Sep 22, 2012 | 2000 Ford Taurus
How to fix loose chain on motorcycle and why won't it shift to 1st?
the chain adjustment wont help this shifting problem, sound like you bent or broke a fork in the ******. the only way to ell on this is to disassemble it.
Jul 12, 2012 | 2002 Honda VT 750 DC Shadow Spirit
Turn signal switch&emergency flasher fixed Now shifting is clunky
More then likely they had the battery disconnected and need to re-flash the Transmission computer.
May 10, 2012 | 1999 Audi A4
I purchased a 96 Metro 1.3L 5 speed about a year ago, and it was hard to get it into gear, and it would often pop out of 3rd gear when driving. Now I have trouble going from first to second without...
your best bet is to get a tranny from an auto wrecker, and replace the clutch while you're at it. If the tranny is that problematic, it's not worth fixing. The clutch kit, which includes the disc, release bearing, and pressure plate, would be under $150, and a used tranny probably $100. Try and find one with reasonably low mileage. Good luck.
Jul 04, 2011 | Geo Metro Cars & Trucks
My gear shift i stuck in park
You can get it out of park as a temporary fix by popping off the little cover to the left of the gearshift, then pushing down on the lever beneath the cover with a flathead screwdriver (or skinny key) and then shifting out of park.
May 15, 2010 | 2000 Honda Accord
Shift lever popped and wont shift into anything
shift cable snapped apart so a new one will be needed
Jan 16, 2010 | 1998 Plymouth Breeze
Transmission shift lever - 91 Toyota V6 4WD pickup
Easy fix! Remove boot, take out four screws, shifter pops up, replace bushing! Keep it in neutral before starting.
May 18, 2008 | 1991 Toyota Pickup
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
