Need carburetor assembly for homelite ut20002a
    Brigadier General:
  • 10,406 Answers
See: http://www.fixya.com/postanswer.aspx?thid=9276949&prdid=0&ctgid=388&ref=unslt
for the same question.
Posted on May 22, 2011
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Price forcarburettorforhomelitef3045trimmer
This is as close as I could come to your model. Several iof the carburetor items for Homelites have been updated or discontinued. In addition to this, Ebay has several Zama carburetors for sale that may fit your machine. This site is pricey but will give you a good idea;
http://www.ereplacementparts.com/carburetor-p-414094.html
Here is a listing of Zama Homelite carburetors currently on Ebay:
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=Zama+Homelite+carburetor&_sacat=See-All-Categories
Dec 13, 2010 | Homelite Consumer Products MightyLite...
Hi, my homelite is approx 12 months old and she has decided to rev at full throttle when she starts. no problem starting. she goes hard out normally. any sujestions would be appreciated. thank you. paul...
Open the cover over the carburetor/air cleaner and watch the throttle arm on the carburetor while you move the throttle trigger. It should go from idle stop to full stop and return to idle stop when trigger is released. If mechanically ok, then look for a very loose carburetor mounting to the engine or a broken heat insulator block between the carburetor and engine--a bad air leak can cause the engine to race uncontrollably (but will cause other damage if allowed to continue). If the throttle arm is holding open, then take the trigger assembly apart at the handle (make notes as you disassemble to get it back together correctly). Look for sawdust obstructing the trigger. Hope this helps!
Nov 10, 2010 | Homelite Garden
Homelite 25cc model UT20002A. How to repalce starter string?
Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
My dad owns a 3 yr old Homelite chainsaw. he is bringing it to me to repair. The chainsaw runs great and as it warm up the idle will rise to the point were it is full throttle and you can't get it to idle...
Check the throttle trigger assembly for free play. You may have to remove the handle section over the trigger to remove sawdust/dirt. Idle changes are usually due to air leakage behind the carburetor--check all fasteners on the carburetor including the ones holding the carburetor to the cylinder. Check the muffler and air cleaner for plugging. Check the cylinder for looseness to the crankcase. Check the throttle return spring on the carburetor to make sure that it is working correctly. Hope some of this helps!
Jun 13, 2010 | Homelite ZR10926 16" Chain Saw
Homelite starts with strarter fluid and then stops
Does the pumper bulb fill with fuel when pumped? I had a similar problem with a Homelite--which turned out to be the location of the carburetor lower-chamber gasket. The diaphragm needs to go to the carburetor body (pin inward), then the gasket and cover plate. Go to:
www.drystacked.com for a 12 page PDF document on Walbro carburetor theory, troubleshooting, and repair. Hope this helps!
Mar 29, 2010 | Homelite ZR10926 16" Chain Saw
I am looking for carb kit for my homelite leaf
Does your model #ut-08010, Have a letter after it. Homelite lists 5 or 6 models of that unit. Plus the kit they show is a complete carburetor with gasket. You will have to figure out which carburetor they put on your blower. Either a Walbro or Zama carburetor and it model to figure out which kit it will need. The homelite kit lists for about $67.00 USD.
You can go to www.precisionope.com and look it up under OEM parts.
Hope it helps.
Good Day.
Oct 20, 2009 | Homelite Garden
Starts but when throttled continues to die
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
May 30, 2009 | Homelite Garden
Computers & Internet Logo
David Payne
David Payne
