Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I have a Lawn Boy 10685. Changed the blade and went to start the mower and the pull cord will not pull. I tried spinning the blade by hand with no luck. I took the starter apart and it spins fine. I check the brake cord and it looks fine. Any other suggestions?
  • 2,510 Answers
Remove the spark plug and try pulling the starter again. You may have a fuel leakage into the cylinder and it has caused a hydraulic lock. Check/change the needle and seat in the carb as this leaking is the usual cause if this type of problem. Good luck and please rate this solution.
Posted on May 22, 2011
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Broken pull cord
replace recoil unit it comes w/pull string
Nov 06, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
When trying to start, it seems that the engine fires early and yanks the cord right out of my hand.
You probably have a bent flywheel key. The timing is off and the engine.
You need to remove the pull cover and then the flywheel nut and lift off the flywheel and inspect the key. They are inexpensive to replace and available at local lawn equipment repair shops.
Good luck and be careful.
Jul 27, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
What locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Sep 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My Lawn Boy Pull Start is Locked Up... If I take the Pull Start off, it is fine. How do you know if it is the motor. I am able to get the blades to turn by hand. They do not turn easy like a windmill, but...
Remove spark plug before you ever try to turn engine by the blade then turn engine. If it is hard to turn your cylinder it is gaulded and needs to be serviced or replaced. Check with a professional repairman. Did you run engne low on oil?
Jul 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have a power master 420 which the pull cord broke on i have replaced it however it doe not seem to want to rewind and is a pig to start now any suggestions please
you must wind the spring up by hand first clamp the sping mecanism down with visegrips or clamp and then feed string trough and tie off. release clamp and string will feed back in
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Pull string locked up
check oil , if you didn't have sufficiant oil you may have blown the motor up . try turning mower up and turnning blade by hand to see if motor is froze. if so you can kiss this mower goodby ,or at least the motor. sorry .by the way maybe you would want to check the oil in your car before you blow it up too
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
308 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
