Question about Galaxy Vacuums
Purchased vanity light galaxy while instructins are clear for black and white wires it also has a green and yellow wire is this just a ground wire
  • 2,510 Answers
The green and yellow wire is indeed the earth wire, black is the live wire and the white is the neutral for US connection. Please rate this solution.
Posted on May 22, 2011
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
Where do the wires go when i am wiring a garbage disposal using a tw o pole toggle switch
The garbage disposal shoud have three wires a green wire goes to ground,
the white wire is neutral, and the black wire is your hot. at the switch, the white
neutral wire feeds straight to the garbage disposal as does the ground, many
times the switch will either have two screws one gold and one silver and the
green is designated as ground. hot goes to the gold screw and the black wire
coming from your disposal goes to the other screw. make sure to turn off power
before working on electrical wires check with voltage meter, its not like working
on your car, if shocked it can be fatal, if unsure handle wires with insulated tools
or gloves. good luck!
Jun 26, 2011 | Vacuums
Hoover Wind Tunnel Bagless cord prong loose, Vacuum shutting off. Do we have to scrap the vacuum?
Home Depot has cord plugs. Cut off your plug, strip apart the three wires, black, white, green. The new plug will have a green screw for the green ground; a silver screw for the white neutral wire and a brass or gold screw for the black or hot wire.
Connect those wires, ensure that none are touching the others, plug it in and turn it on.
Good Luck,
Gary
Jun 22, 2011 | Hoover U6630-900 WindTunnel Bagless...
I have a clarke bench grinder model 1002. I have a light that I would like to attach into the wiring though the grinder wiring in it's base. The light has two wires, and the grinder has a ground that...
Attach the white wire on your lamp to the white wire on the grinder.
Attache the black wire on your lamp to the black wire on the motor side of the switch.
This will give the lamp power any time the grinder is turned on.
You can put a switch inline of the black wire to the lampp and it will allow you to turn it off when not needed
OR
You can attach the white wires together and the black ones before the switch.
If you choose this way you will need a switch as the lamp will be power all the time.
May 21, 2011 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
GE on/off timer for a bathroom fan - switch has four wires Green - ground White - neutral Black - power Blue - lead My fan has two - white neutral and black lead I have tried...
I would guess that the black wire on the timer is the power in and blue is the power out to the fan (hook it to the black wire going to the fan) The other colors are right.
Mar 23, 2010 | Vacuums
How do I fix an electrical plug on my vacuum
cut it off. go to a hardware store and get a three prong plug which you can install onto the wire.
when you prepare the wire you will see a black wire, a white, and a green.
black goes to the brass screw, white goes to the dull screw and green goes to the green ground screw.
Sep 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
REPAIRING A BISSEL GREEN MACHINE, REPLACING PUMP. DON'T KNOWWHICH WIRES GO WHERE ON PUMP
hi
if theres only three wires , green, black and white then the green wire is a ground which goes to an exposed metal exterior screw on the pump. It doesent matter which way the black and white go, it will work either way but if when you try to attatch the connectors theyre harder to attatch one than the other then switch it to the most easier way to attatch. Make sure to connect the green ground wire, it is very important and always try plug the shampooer into the bathroom where the ground fault plug is- its an added level of security in case theres a ground fault.
J
Jul 11, 2008 | Bissell Vacuums
Vacuums Logo
126 people viewed this question
Top Galaxy Vacuums Experts
JoeVacs
Are you a Galaxy Vacuum Expert? Answer questions, earn points and help others
