Question about HP Office Equipment & Supplies
Will not copy unit keeps on continuously clicking
    Sergeant:
    Champion:
  • HP Expert
  • 345 Answers
It may be low on toner. Some machines "click" continuously when adding toner.
Posted on May 22, 2011
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
One of our units was beeping every 20 seconds. I replaced the battery but it continues to beep. Now I have another unit doing the same thing. Help...
According to the Owners Manual if it's showing an error message or code, it should be returned to the manufacturer. For more info click on the link below which is your Owners Manual in a pdf format.
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COEG-3_900-0113en.pdf
If the link doesn't work when you click on it, simply copy and paste it into your web browser.
Jan 26, 2011 | Kidde Nighthawk Combo Gas/co Detector
Internal breaker in the plug keeps clicking off, when i reset it clicks off again. ive replace the Main House breaker, thinking it may be old, but still the inline breaker keeps popping off. this Ac/Heat...
Inspect the wiring and the terminals. There may be a short circuit somewhere. If you have a tester, you may check the continuity of the two wires. Test the wires after the breaker, the part that goes to the unit.
May 05, 2010 | Fedders AER24E7A Air Conditioner
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
I have vista how can i reset my keyboard to default settings ???
Go to Regional and Language Options:
  1. Click the Administrative tab.
  2. Under “Language for non-Unicode programs”, make sure that you have “English (United States)” selected.
  3. Under “Reserved accounts”, click the “Copy to reserved accounts” button.
  4. Click Continue for UAC prompt.
  5. Check “System accounts…..” and click OK.
Aug 29, 2009 | Sharp Computers & Internet
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Continual downloading
remove all the printers from the list and then install the printer again from the disc
Oct 17, 2008 | Office Equipment & Supplies
20 people viewed this question
Seeker5211
Seeker5211
