Question about SanDisk Sansa E280 MP3 Player
Blue Screen of Death
I added some music onto my Sansa and correctly disconnected it. It began to do it's Refresh Database, like it does every time I put in new music. However, before it finished the process, the entire screen went blank and turned into a blue/green/white screen with what seemed to be scrolling unaligned bars (or maybe tiny code?). I tried restarting it, but came to the same result. Is there any way of fixing it, or do I need to cash in on my warranty?
Thank you very much,
Mukani
  • Anonymous Aug 17, 2008
    I too have the same problem. I tried to reset by holding down the power button and this didn't work. I tried going into recovbery mode, but I didn't know what to do when the recovery mode screen was activated. I did a hard reset by popping out the battery, but this didn't work either. HELP!
    Stephanie
  • aphrael11235 Sep 17, 2008
    I tried updating the firmware. I'm not sure how this will help because the thing is completely comatose, but I tried. IT"S STILL BLUE AND STRIPY. I just got this 2 weeks ago, but it's a referb so it doesn't have a warranty. :( Please help me!
  • 758 Answers
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Aug 19, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Busted?
Try to connected it back up to your computer in the msc mode and then disconnect it wait for it to refresh it's database and it should be working with titles.
Oct 10, 2008 | SanDisk Sansa e260 MP3 Player
"refresh database"
Get the Vista compatible version of the software from Sansa's website
May 24, 2008 | SanDisk Sansa e260 MP3 Player
Thought it was fixed
You're not screwed... Just lock your sansa and then hold REC button when starting up your sansa. Connect your sansa to the computer. then a device called 16MB-FORMAT should be in My Computer. Put this file : "http://www.MegaShare.com/392319"
onto that device. Now disconnect your sansa from your computer, and let the sansa do everything it needs to do. Then it will restart.
Make sure you unlock it. After this your sansa should work fine.
Apr 13, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Jan 19, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Very weird...
'Refresh Database' doesn't mean everything is erased. It only means it's writing the progress that you made, onto the computer. It stays on 'Refresh Database' for about maybe 5-10 minutes. It refreshes its database every time you disconnect your MP3 player from the computer. What it does when you disconnect it from the computer is it saves any unsaved changes made to it and overwrites the memory or data.
Oct 28, 2007 | SanDisk Sansa E280 MP3 Player
Frozen on Refresh Database
Take out the four screws on the back and pop out the battery then put it back on. Make sure you synced the songs properly. Add to the problem how you added your songs and I might be able to help.
Good Luck
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
