Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP
There is oil in my air filter and pooled around the top of the yellow part of the mower and now it won't start. Do I have an oil leak somewhere or what?
    Novelist:
    Champion:
  • 222 Answers
Perhaps you tipped your mower over to clean underneath it? If you tip it the wrong way, yes, the oil will run up and into the carburetor, then out the carb and into the air filter. An oil leak would not cause this to happen due to gravity. If this was caused by tipping the mower, then let it set upright for a time and let everything run back to where it's suppose to go. It will take a bit to start it, but should work then. I'm hoping this is what your problem is. I hope this helps.
James
Posted on May 27, 2011
2004 volvo c70 won't start after changing air filter
Thats interesting.
Did you fail to plug a connector back in somewhere ?
Is the air filter cover sealed with no air leaks ?
Jul 26, 2012 | 2004 Volvo C70
Oil and filter for kohler 23hp engine in troy bilt mower
There is generally a pipe coming out of the side of the engine just above where it mounts to the mower frame. It will generally have a six sided cap at the end. Get a pan to drain the oil in that will hold approx. 1 gallon. Most small engines have at most 2 quarts of oil, but this leaves some room at the top to avoid oil sloshing over the side.
Get the proper sized wrench, or an adjustable wrench (Crescent wrench) to remove the cap.
Before you remove the cap, run the engine for a minute or two--not much longer-you want to warm up the oil so it drains well but not get so hot that it burns you.
Remove the plug and allow all the oil to drain into the pan... let it run even only a thin stream is coming out. Many small engines don't have oil filters and it's best to get all the used oil out of them you can.
If your engine has a filter, you'll want to replace it also. You might be able to remove it with your hands, if not, go buy an oil filter wrench of the right size (take your replacement filter as a guide when you go to the store). Be careful when removing the filter quite a bit of oil will come out. Put a pan under it if you can, if not, push a large rag under the filter to catch the oil and stop it from pouring on the ground. Unscrew the filter, then turn the open end upright to catch any oil in the filter. Drain the filter in your oil pan, etc.
When you install the new filter, put some new engine oil on your finger and wipe it around the black rubber gasket. I also like to put some oil in the filter as this gets oil to the engine a little faster when you first start it after the oil change. If the filter is mounted on its side you can still put some oil in it--the filter will absorb it. Quickly screw it on and you won't spill any.
You'll feel resistance from the gasket touching the filter base on the engine, after a couple turns--tighten it only about 3/4ths of a turn more--don't use a filter wrench to install it--they get stuck in use and you'll have a difficult time removing it at the next oil change.
Make sure the cap is screwed back on the drain pipe, then put the correct amount of fresh oil into the engine. You normally pour it into the spout where the dip stick is, or else there is a cap on the engine marked for adding oil. DON'T OVER FILL IT!! Overfilling can cause the oil to be drawn into the carburetor; and may increase crankcase pressure that will cause your seals to leak ,etc.
Air cooled engines rely on engine oil to help cool them. For this reason, keep the oil up to the Full mark on the dip stick--check it every time you use the machine and top off as needed.
A cheap but effective oil drain pan for lawn mowers and lawn tractors is to get an old rectangular gallon jug like antifreeze comes in. Make sure it is completely empty--if you wash it out, catch the rinse water and dispose of it properly. Anti-freeze has a sweet taste that attracts animals, but is highly poisonous. It's also against the law to wash it down a toilet, household drain, or the gutter on the street. Also the auto parts store won't accept your used oil if it has antifreeze in it.
Make sure you have a tight fitting lid on the jug. Lay it on it's side and use a sharp knife or scissors to carefully cut a large square hole out in the side that's facing up. Round the corners if possible. Leave about 1" of the top surface (the surface you're cutting) all the way around. This will make it stronger, and also helps contain oil that sloshes around when you move it. It also will allow you to drain the oil through the pour spout into a jug to take to an auto parts store for disposal.
Old gallon milk jugs are handy to transport oil in but be careful the lids don't pop off due to rough handling. I prefer using an oil drain pan with a large lid over the opening with a smaller lid over the spout. Leave it flat when carrying it and you won't have any oil leak out. Also, don't store used oil in milk jugs as the plastic breaks down quickly and you could have oil all over your floor.
This is a long comment, but I hope it was helpful.
drechsel97
Jun 25, 2012 | Garden
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
My push mower was stored for over a year tipped up, and all the oil leaked out. It won't start now.
The paper air filter will now be soaked with oil, remove the filter completely, remove the spark plug and crank the engine to evacuate any oil above the piston, clean/replace the spark plug and re fit, top the engine oil up if low, now attept to startbthe engine with the filter still removed, once it starts it will smoke heavily until it clears the oil in the bore.
Mar 04, 2012 | Poulan "Poulan" Push Mower
Was using my toro lawn mower when big clouds of white smoke started to come out of it. I put oil in the oil tank and it started to pour out the air filter. How is that? Now it won't start at all.
You have big problems my friend! You have blown a head gasket, or broke the rings around the piston. The gasket isn't as bad as the rings. But neither is a good sign. It may be time to get a new mower; sorry for the bad news..... :-(
Jim
Aug 11, 2011 | Toro Power Lawn Mower
I have had mower for some time and all of sudden it is going through gas about twice as fast as it did. there are no leaks, i've changed plugs gas & air filters and changed oil/filter. I don't...
Let it idle for a few minutes and check around the gas cap,sometimes they leak.You could also add some Marvel Mystery oil to your gas tank,to clean around the pistons.
May 12, 2011 | John Deere Garden
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP Logo
264 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
