Question about Sanyo Cameras
Let camera fall and seem to have lens damage , it will not move or focus
  • marthaderv Aug 15, 2008
    very honest and helpful thank you
    i did fear the worst when it fell
  • 876 Answers
I don;t ever like to say this, but I fear that your camera may be kaput. have you made sure that the batteries are still contacting well and the battery door is still closing tightly? If they are, then you should have power to your camera. Does anything happen when you turn it on? I would take it to a camera shop and get an estimate for service and whether it would cost more than a new camera. I don't know what you paid for your camera, but service on digicams is expensive and sometimes it is better to look for a good sale and purchase a new camera. Good luck to you.
Posted on Aug 15, 2008
Repair - How can I fix a broken lens/AF/MF?
If you have another lens, try that on the camera to determine if the damage is the lens or the camera. If the lens is damaged, just buy a new one, I would not trust the elements to focus true on a lens that has had an impact severe enough to cause this problem. As this is the standard lens that ships with most Canon Packages, you can likely find a cheap one online.
Sep 10, 2016 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Tip
Explaining Camera Focus
Camera: Focus We've seen that a real image is formed by light moving through a convex lens. The nature of this real image varies depending on how the light travels through the lens. This light path depends on two major factors:
  • The angle of the light beam's entry into the lens
  • The structure of the lens
The angle of light entry changes when you move the object closer or farther away from the lens. You can see this in the diagram below. The light beams from the pencil point enter the lens at a sharper angle when the pencil is closer to the lens and a more obtuse angle when the pencil is farther away. But overall, the lens only bends the light beam to a certain total degree, no matter how it enters. Consequently, light beams that enter at a sharper angle will exit at a more obtuse angle, and vice versa. The total "bending angle" at any particular point on the lens remains constant. camera-diagram3.gif
As you can see, light beams from a closer point converge farther away from the lens than light beams from a point that's farther away. In other words, the real image of a closer object forms farther away from the lens than the real image from a more distant object. You can observe this phenomenon with a simple experiment. Light a candle in the dark, and hold a magnifying glass between it and the wall. You will see an upside down image of the candle on the wall. If the real image of the candle does not fall directly on the wall, it will appear somewhat blurry. The light beams from a particular point don't quite converge at this point. To focus the image, move the magnifying glass closer or farther away from the candle. camera-diagram2.gif
This is what you're doing when you turn the lens of a camera to focus it -- you're moving it closer or farther away from the film surface. As you move the lens, you can line up the focused real image of an object so it falls directly on the film surface. You now know that at any one point, a lens bends light beams to a certain total degree, no matter the light beam's angle of entry. This total "bending angle" is determined by the structure of the lens.
courtesy of HowStuffWorks.com
on Mar 21, 2008 | Canon PowerShot A520 Digital Camera
My autofocus will not work all the time. when I want to zoom in for closeups it will be out of focus
This means that there is a alignment issue as the auto focus seems out of setting. This can be due to damage on the settings or a possible shift in the lens setting. This is due to a damage on the lens setting or a jammed motor drive. You will need some expertise to remove and check or reset the lens settings. If not take consensus as a false move can do more harm. need to remove the camera and the auto focus in the lens hood to test the motor drive, movement and action.
Oct 09, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
My camera lens won't move. I recently was out on a photoshoot with friends, and I ended up falling down with the camera in my hand while the lens was extended. At first it didn't move at all, but I got the...
I am sorry to say that this is a problem related to the lens mechanism. The lens gears may have kinked/slipped when you fell down and this seems to be the reason why the lens cannot extend retrace. Unfortunately this is one repair that you don't wanna do yourself. The lens assembly has to be completely disassembled just to know the exact cause of the problem and any further damage means a new camera. Panasonic will charge you the cost of a new cam to fix it. So to get an estimate from your local camera tech would be the way to go.
Aug 26, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Lens error, cannot focus, lens not retracting
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 21, 2010 | Canon IXUS 860 IS Digital Camera
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
18 - 135 lens won't autofocus after fall - is it worth reparing?
Hi Vink,
I would recommend that you at least let someone at a camera shop take a look at your lens. Or contact Nikon. Here is a list CLICK HERE of Nikon authorized service centers, hopefully you are located near one of these. Or you can call Nikon for some advice. You never know, it may be repairable.
If can live with it as a manual focus lens that probably would be a good solution also. Then you could buy a new lens with the money you would have spent on the repair. Actually you are lucky that the lens can still focus after a fall.
I hope this helped and good luck!
Nov 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Focusing wont work after dropping
probably the lens inside is damaged or the mechanism which moves the lens is damaged. Focus works with a moving mechanism which moves the lens back and forth.
Oct 07, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Fuji digital camera A370 lens sticking
It seems the life of digital cameras are 2-3 years. The camera has lens gear problem. The lens assy fails most on digital cameras with moving lens. The plastic gears in the lens assy. are quite fragile in design and when used regularly, gears tends to wear down and eventually damages the lens movement. Many time a small impact or stress on lens when extended do the same damage. The parts are sold as a lens assy and repair cost may run around $100.
Mar 18, 2007 | Fuji Finepix A370 Digital Camera
Cameras Logo
29 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
