I bought a Canon Lide 110 scanner. I can't get it to work and I get an error message saying ' a driver supporting solution menu ex is not installed ' I have windows vista. Can anyone please help
    New Friend:
My pc windows 7 . I want to use scaner but
I start my computer I get a screen that says "A driver supporting Solution Menu EX is not installed." ... I haven't done any problem-solving.
Posted on May 28, 2013
2 Suggested Answers
  • 368 Answers
SOURCE: I purchased a new Canon
Glad to help YOU!
You have to do like this:
# uninstall everything related to that scanner and remove the registry values. To do so I'd suggest you to download and to install REVO UNINSTALLER; it's FREE and it does a great job! Get it from HERE.
# get your driver for your Canon Lide 110 for Windows XP from HERE.
# go on START > CONTROL PANEL > ADD NEW HARDWARE and plug in your scanner;
# choose "Have Disk" for the installation method and provide the path = where you have downloaded the driver from the indicated web address (the second #)
# let the installation roll on.
You're done!
In case you still have problems just let me know.
My best wishes!
Posted on Mar 16, 2011
Canon solutions menu "unexpectedly quit"
I have the same problem. There is no cartridge in the scanner, no paper fed. It is just a scanner. The problem started after installing Mac OS 10.8.
Feb 16, 2013 | Canon 4507B002 - Canoscan Lide 110 Flatbed...
I installed the new Canon LiDE 110 scanner drivers. When I click on the Scan button, it gives the error msg: Cannot Communicate with scanner. Cable may be disconnected. Scanner driver will be closed
I was getting that same error message, every second time I tried to scan something. I had the scanner connected to a USB 3.0 jack. I switched to USB 2.0 jack, and the problem was solved.
Oct 06, 2012 | Canon CanoScan LiDE100 Flatbed Scanner
Canoscan Lide 110 driver
Perhaps you have forgotten to unplug the scanner before
scanning? That's what happened to me. I kept getting
different error codes, 5,202,63 or 5,202,52 or 5,202,54 and
also a message that the driver was not in the TWAIN folder.
According to the help file the problem might have been due
to my nfts file system. I also tried downloading various
new drivers. Nothing helped until I noticed that I had not
unplugged the scanner!
Jun 27, 2012 | Canon CanoScan LiDE110 Flatbed Scanner Inc...
I purchased a new Canon lide 110 scanner. Computer won't communicate with scanner after many attempts to re install drivers. Canon tech support says problem is within XP not opening driver \
Glad to help YOU!
You're done!
My best wishes!
Mar 16, 2011 | Computers & Internet
Have no installation disk for canon lide 80 scanner . OS X 10.6 (Snow Leopard)
An error message popping out saying:
release the lock switch, deatach the I/F cable and receoonect.
scanner driver will be closed.
Code: 2,179,0
I have unlocked it and recoonect the cable. but my scanner cant seem to scan through it.
Oct 30, 2009 | Canon CanoScan LiDE 80 Film Flatbed...
Impossible to scan additional pages without starting all over
The sole message is "Scanner error"? ... Odd.
I'm not sure what version of OmniPage you're working with. This manual's probably in the ballpark:
ftp://ftp.scansoft.com/files/support/manuals/op15guide.pdf/
It looks like they suggest a different route, a different workflow process -- scan in all your images at once, then handle processing in a batch. I think you do some processing, then try to get the next image. This may have nothing at all to do with your "scanner error," but it's worth a try (and if/when you get the error resolved, this is a smarter way to use your time).
Before you go down that road, though, look for some updates. Some errors are often fixed with updates, and it's worth a try.
Look for updates to OmniPage. I believe you can look through the program itself -- was it Help: Update? You can also look here:
http://support.nuance.com/downloads/
There may also be a somewhat newer driver for your scanner; I don't know; the only drivers there are about a year old. The link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=119&modelid=15562
Scroll down a bit, click on the Drivers and downloads page.
Please please please let me know if this doesn't work for you. And if it doesn't, if you can write down the exact error message, we can try to find out some more answers. If you just bought it, you may also be eligible for free tech support from Canon and/or OmniPage; I don't know. They'll tell you to follow these same steps as well, I'm sure. =)
Dec 05, 2008 | Canon CanoScan LiDE 90 Flatbed Scanner
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed code 39
Did the message say:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Download the Delete driver application from Canon's website and run it. After deleting this and rebooting, try installing again.
May 29, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Computers & Internet Logo
1,048 people viewed this question
David Payne
David Payne
