Question about Maytag Dryers
Older maytag dryer taking too long to dry towels, why?
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on May 26, 2011
Maytag dryer MEDC400VW0 takes 4 cycles to dry towels, they get warm and create a lot of steam. Have already replaced the heating element. What should I try next?
Sounds like a restricted vent system either internally in dryer, linked vent behind dryer, or obstruction in vent going out of house. Also could be blower wheel stripped out and not blowing much air.
Nov 10, 2017 | Maytag Dryers
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
Dryer won't dry have to do it twice
first check to make sure the lint basket is clean and free of lint, then lift it out and if possible reach in with a vaccum extention or tongs and see if there is a build up of lint in the front of the dryer, below the screen. that maybe blocking the flow of air, I cleaned one out for a friend, he had just started renting the apartment and the washer and dryer were there, but I do not think anyone ever checked below the basket. I am sure they were one dryer load away from a fire and he was living in a older row house. I ended up taking a have a grocery bag full of lint out of the front of the dryer, it was just packed in from years of use. but if there is not good air flow through the dryer the cloths will not dry.
2. also you can put a dry towel in the load and it will pull moisture out of the really wet clothes and they should dry quicker.
3. make sure your washer is working right and the spinner is taking all the extra water out, if they come out of the washer wetter it will take longer to dry them.
hope some of this helps K
Jul 04, 2014 | Maytag Dryers
My dryer takes too long to dry clothes. It could take up to 4 hours to dry a load of towels on high setting. What could be the problem?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Oct 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer takes forever to dry clothes
Check out this tip... it will help you to find out what is making it take so long..
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 26, 2010 | Maytag PYE2300AY Electric Dryer
Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Mar 11, 2008 | Dryers
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
