Question about Kenmore Kitchen Ranges
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
  • Kenmore Master
  • 17,970 Answers
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Posted on May 22, 2011
Getting beeps and f1 error code after canceling cleaning mode a little early.
Hi dear.According to your explanation,Getting beeps & F1 code meaning: F1
Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced.
Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC
I hope that helps.Thanks.
Sep 03, 2010 | Maytag MER5775Q Electric Kitchen Range
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Aug 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Electric panel on stove displays
check the sears kenmore site they have info on error codes.
Aug 22, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
Continuous warning Beep & "F3" displayed.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 22, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 8114p643 showing f1.
F1 is either a bad electronic control board or a bad touch pad.
You find the solution on :kenmore oven with "F1" error
I quote:
"You have either a bad ERC (clock) or a bad touch pad.
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
If you can't find a new ERC you can send yours to stove clock repair and get it repaired!"
Dec 14, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
390 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
