I have a AL 1715 Monitor that takes forever (sometimes Hours) to appear . Power Light comes on but just flashes Green. Bought new power cord and video cable but still have the same problem. Dont have acess to another computer or moniter Any help ?
  • Computers & ... Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on May 22, 2011
Power adapter issues...
If you can jiggle the the power cord right at where it plugs into the computer and sometimes the green light comes on, that means your DC Power Jack is bad. There was probably nothing wrong with your other power cord. When the DC Power Jack is bad the laptop will not power on if the battery is drained of all of it's power because the Power Cord can't charge the battery.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 02, 2012 | Dell Inspiron 1525 Notebook
Monitor won't turn on
in the output section of smps some condensors are faulty
Dec 12, 2009 | Computers & Internet
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
