Question about Lifetime Acer Aspire 5810TZ-4657 Replacement Laptop Power AC Adapter / Charger (91812042845)
White screen, whats the problem of my laptop?
    Brigadier General:
  • 10,406 Answers
> white screen
Usually, this is a bad/intermittent connection (via a ribbon-cable) from the motherboard to the LCD screen. Open/close slightly the hinged LCD screen, to see if you can find a "sweet-spot".
Or, take the computer to a qualified technician, for professional trouble-shooting and repair.
Posted on May 22, 2011
Dell laptop flashes orange and white when adapter plugged
Could you please explain better? What is flashing orange and white, power button or screen? Your laptop has also beep codes, do you hear any beeps when you start? What color is the screen when you try to turn it on?
Nov 06, 2015 | Dell Computers & Internet
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
Laptop white screen
Having a laptop screen turn white is one of the most frustrating problems a user can experience since it prevents use of the laptop to find a solution.
A white laptop screen indicates a serious problem with the laptop's hardware, and no easy solution to this issue exists.
Just diagnosing this condition requires advanced computer knowledge.
Identification
With this problem, the laptop itself will power on and load the operating system as per usual, but the screen will become a complete, static white, according to LaptopRepair101.
No particular brand or make of laptop falls prey to this issue more than any other; it can happen to any laptop.
Causes
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop.
The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard.
The issue can also reside strictly with the motherboard or the screen might contain a defect.
Considerations Users can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists.
Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
Motherboard Problems
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop.
This requires the user connect the inverter board--the power supply for the LCD backlight and the video cable to the test LCD.
If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Prevention/Solution
Taking apart a laptop screen may make some users feel uncomfortable, so you can use an external monitor connected to the VGA port common to most laptops if the processor and hard drive still work fine. Using an external monitor requires finding the proper function key command to toggle between the LCD and external monitor.
Warning
Taking apart the LCD screen on a monitor likely voids any manufacturer's warranty.
Consider visually checking the video connection to the laptop screen as a last resort if no other viable options exists.
The service manual that came with your laptop likely offers some tips to disassembling the computer, or conditions that could void the warranty.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Jul 02, 2013 | Dell Inspiron Computers & Internet
Why does my screen keeping going white and i have to move the screen about to get it back, battery fully charged.
HI
The flex of your laptop is what is giving you that white screen
The flex connects the screen to the motherboard of the laptop the more you open and close the laptop, the flex gets weaker
The solution is to get a repairer to change the flex for you,that will solve the white screen
Thank you for visiting fixya
Mar 09, 2010 | Samsung NC10-14GW Notebook
The display turn white >>>what can i do?
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Jan 18, 2010 | Samsung NC10-14GW Notebook
Hello I've got this problem. when my computer running, sometimes my screen go white screen and i can't see at all to the windows, just white screen. but all function is ok so i press power button to...
got this from a friend: Apparently some series of Acer notebook came with BAD_EDID laptop display. The only thing wrong is the checksum which is 9D and should be 1D. Powerstrip 3.76 (registered version) managed automatically to correct EDID.
There is no problem with drivers from 101.x series, but with any newer driver max. resolution is 1024x768 and the picture is in left upper corner of the screen with black bar on the right and smudged taskbar to the bottom of the screen. After installing and restarting resolution is set to 800x600 what results in white screen whit thick black bar slowly appearing on the screen.
Jan 27, 2009 | Acer Aspire 3690-2196 Notebook
White screen zd7000
Just click on the download link and follow the on screen directions Altough i think you need to replace the lcd screen. It might be cheaper to buy a new notebook
Here is the driver site
Oct 06, 2008 | Acer Aspire 5630 Notebook
White screen zd7000
It may be a power problem. The battery may not be charging.
Aug 16, 2008 | Averatec 6100 Notebook
Lifetime Acer Aspire 5810TZ-4657 Replacement Laptop Power AC Adapter / Charger (91812042845) Logo
295 people viewed this question
Top Lifetime Computers & Internet Experts
Corey Bartlett
Level 1 Expert
Paul Bade
Alan Hohenbrink
Alan Hohenbrink
Are you a Lifetime Computer and Internet Expert? Answer questions, earn points and help others
