Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
I have LV371T and the clock timer setting is broken can it be fixed at home ? the On- Off setting ,the on setting is broken ?
  • Malibu Master
  • 5,089 Answers
Set the clock to DST, on my GE JRP20 B wall oven
set the clock to a new time:
TIMER/CLOCK Pad
To set the clock, touch this pad twice and hold 3
seconds and then touch the + and - pads. The
time of day will flash in the display when the
oven is first turned on
Mar 22, 2017 | GE Home
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
My Sony Bravia will work for a few minutes then go into standby mode. How can I fix this problem?
This could be the sleep timer. Press "Home" and select "Settings".. Go to the "Setup" menu and then to "Clock/Timers". Select "Sleep timer" and Set to "Off".
Sep 23, 2013 | Televison & Video
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Install new timer for pool about 5 weeks ago. clock does not work or timer. what do i do to fix problem?
Do not tirn the clock dial counter clockwise as it will brake the teeth on the plastic gear causing the clock not to turn. If the gear is broken The mfg. will mostlikley send a new one for free with an exploded view. It is very easy to replace. Don't forget to shut off the power first as the points will be exposed during your gear replacement.
Aug 17, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Apr 02, 2009 | Hardware & Accessories
Range clock/timer broken
That type of clock is highly failure prone.
May 25, 2017 | Kitchen Ranges
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
478 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
