Question about Linksys Computers & Internet
I'm using a linksys nh10005.v2 hub to network an AT&t DSL modem to 2 computers, a PC running XP and an imac G4 running X 10.4.7 the PC connects fine but the Imac won't connect to the hub, I'm not quite sure why.any suggestions? thank you for you time and help.
debbily
  • 101 Answers
SOURCE: 3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Posted on Oct 14, 2007
  • 556 Answers
SOURCE: wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Posted on Dec 08, 2007
serra_baby
  • 144 Answers
SOURCE: zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Posted on Aug 07, 2008
  • 5 Answers
SOURCE: EMbarq/Zyxel 660R/eHarmony/Windows Don't Play together well
Upgrade to the latest firmware on the modem, disable the modem firewall, or bridging the modem will resolve this
Posted on May 26, 2009
SOURCE: linksys WAG200G
Pls find below URL link to download firmware’s compatible with STC, in case any of your consumers who has purchased modems earlier are facing problems due to STC upgrading their network.
Note # The latest models of WAG 120N, WAG 160N AND WAG 320N have the STC Compatible firmware’s preloaded from factory.
MODEL NO
LATEST FIRMWARE
DOWNLOAD URL
WAG 200G
1.01.09
http://www.linksysbycisco.com/UK/en/support/WAG200G/download
OR
you can also login into the router by typing 192.168.1.1 and default username/password is admin/admin and change the DSL modulation from multimode to T1.413
WAG 54G2
1.00.19
www.linksysbycisco.com/ANZ/en/support/WAG54G2/download
AWARD WINNING TECHNICAL SUPPORT ARABIC/ENGLISH NO FOR LINKSYS 8008445905
Steps to upgrade the firmware
Log on to the router > go to Administration > go to firmware upgrade > browse the downloaded file > click upgrade
Posted on May 28, 2010
Can I connect this switch to a DSL modem and then connect two computers to the switch?
I DON'T BELIEVE IT'S POSSIBLE YOU NEED A ROUTER.WIRELESS N WOULD WORK GREAT.I KNOW THIS BECAUSE I HAD THE SAME PROBLEM.I ENDED UP GETTING A LINKSYS ROUTER.HOPE THIS HELPS.
Feb 19, 2012 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I have dsl coming into house. to modem, motorola , style mstatea , 12 dc. to main house computer. works good. tried to hook up modem linksys cisco wrt260n v2, using 1 & 2 ports. 4 ports in all and it...
You shouldnt add multiple routers to the mix, what you should use is a switch. A switch will allow you to add multiple devices at the same time without any issue.
Jul 15, 2011 | Computers & Internet
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Jun 06, 2011 | NetGear ProSafe GS108 8-Port Gigabit...
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
Need help!!
Just enable the DHCP capability of your DSL router and then connect the Linksys hub to your DSL router then your PCs to the Linksys hub.
Jul 03, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
How to hook up the Ethernet 5port Workgroup Hub Model No. ew5HUB
To start with please make sure it says router on it as the title says "Networking Hub". These are two different devices. If not return the Hub and purchase a Linksys Router then follow instructions below.
Assuming you have a router:
Before you begin unplug the power from the Cable or DSL Modem before you start as they will have to be powered on in a particular order I will discuss later.
Your cable or DSL modem will have a cable coming out of it that looks similar to a phone line except a little larger. The cable will say CAT5 or CAT6 or Ethernet on it.
On your Linksys Router there will be a ports/jack that you can plug the Cable into from your Cable/DSL Modem. You want to look for one labled "WAN" or "Internet". Plug it in then plug in the power to your Cable or DSL Modem. When the "Ready" light is on the modem, plug in the power cable to your router.
The next step is hooking it up to your computer. There will be anywhere from 1 to 8 more ports available on your Router that is number 1,2,3,4, etc. Plug another Ethernet Cable into any one of those ports. With the other end plug it into your PC or Laptop, there is only one port/jack on your computer that this plug will fit in. Power up your PC and voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | Linksys Instant Networking Hub
NH1005 network hub
I assume that besides the 2 computers you also have a cable or dsl modem connected to the hub in order to provide the actual connection to the internet.
The problem may be the fact that this is a hub and not a router or gateway. The problem is that although it will allow you connect more than 1 computer to the internet, it does not do any good if you Internet Service Provider only supplies you with 1 IP address. You need something that handles Network Address Translation (NAT), like a router or gateway device.
Sep 28, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Just connected to cable modem from dsl
two things are you hooked up from the dsl to the router via Ethernet or usb is so check the settings in the router, it should be auto, so it could choose but lets not assume anything.may sure dhcp client or server is enabled on the router, if not it would not pick up the ip adddress from dsl.
Is the mac address of your computer hardcoded to your dsl, if it is then you would have to clone your pc mac to the router for it to work.
If this is not the case, try a different router if it works the router is faulty. if that does not work plug the dsl directly to the pc and go to start, run type ipconfig /all if you recieve an ip address and you can see a dns address from your isp and you can go to the internet, then the problem is your router, if not the problem is with you isp dsl, please contact them. was this helpful let me know.
Jun 03, 2008 | Computers & Internet
Changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Dec 29, 2007 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
44 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
