Question about Amana Refrigerators
Hot spots on outside of Amana fridge. sxd22s2w model
  • Amana Master
  • 2,183 Answers
If it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that too.you might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close together.you can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
Posted on May 22, 2011
Fridge door seals are hot fridge not cold
The door seals get hot so they don't stick to the cold metal. Check and clean the outside parts; one looks like a sort of radiator. Make sure this is clear.
Apr 02, 2012 | Amana Refrigerators
The outside of the fridge where the rubber seal makes contact is almost too hot to touch.
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Apr 05, 2011 | Amana Refrigerators
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
How do I get access to the coils on an Amana model SXD22S2W,
on most refrigerators the plastic grill is a snap on most service tecks carry a long
brush that looks like a cats tail to clean the condenser coils a long bottle brush will also work but be gentle the tubing is metal the fan is normally located looking from the front back left corner if you have a plastic putty knife you can insert on top behind plastic close to the side and easily pop forward very few units are secured with screws ron
Dec 05, 2009 | Refrigerators
Amana side by side fridge model sxd22s2l freezer/fridge not cold
they can get up to 305 degree F they can make brown spots on floor... yes they get very hot(is normal)
Aug 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Top Freezer Refrigerator is hot to the touch on the outside on the sides by the freezer. Still working fine inside. Is something getting ready to break inside?
The problem was the fan. It was hitting the metal enclosure and had stopped working. We made an adjustment and cleaned it and now it works fine and the hot spots are gone.
May 04, 2009 | Refrigerators
Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
Jan 10, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigerator water dispenser
could be carbon particles from a broken carbon filter cartridge. replace the filter and flush about 5 gallons of water before checking the water again that comes out of the dispenser.
Feb 19, 2008 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
