Question about GE Refrigerators
Hello, I have a fridge that I'm going to sell, but I have no idea how old it is....can you tell me if I give you the model and seriel number?
  • 1,543 Answers
You posted under a heading of a GE refrigerator. If it is, try this to find age: http://www.geappliances.com/service_and_support/faqs/
If not a GE product, check the manufacturer's web site for similar info.
Posted on May 22, 2011
Frig and freezer both just quit working
on the compressor there's a start device that fails,most likely this is your problem,unplug the machine,remove the back bottom panel and look at the compressor,you'll see the device on the side of it,pop off the clip,the cover and slide the device off of the compressor,easy way to test it,just shake it,if you hear little pieces rattling around inside of it the device is bad.this has an overload and relay in it,they fail and the compressor stops running,call your parts store,give them the model number and tell them you're looking for the start device and they will sell you the correct part,if it's a side by side open the fridge door,look on the right hand side wall up near the ceiling and you'll see a tag with the model and serial numbers,just need to give them the model number.good luck.this is a common problem.
Dec 03, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
2002 kenmore coldspot refrigerator shuts off periodically yet the lights is still working
sounds like you have a bad cold control,when it stops hit the area near the control,if it starts it's bad or if you say it runs when you move the control most likely the control is bad,freezer is on top,open the fridge door,look on the left side wall up near the ceiling and you'll see the model number,call your parts store and tell them you need a new thermostat or cold control ,give them the model number and they will sell you the correct part.
Nov 01, 2011 | Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
Hello, I have been given an Admiral fridge. I can't seem to see an obvious model Nos but on the back 2 numbers: R134A and GC2227SDFW. Do these mean anything, as we would like to know if there is a...
HI,
The model number you gave was correct. I looked up the model and it does not list a filter, so you can use any in-line filter you find at the local hardware store or home improvement center. Just ask a clerk for a 1/4 in-line filter which should be installed between the water supply (valve on wall or source) to the fridge itself.
Not very expensive or time consuming task to do.
Good Luck
Jul 27, 2011 | Admiral 26 cu. ft. Side-By-Side...
I cleaned my fridge only with paper and cloth towel last time. Ever since, the freezer is working but fridge completely shut down. I tried to switch on and off. The light is on in fridge but it's not...
It's not the compressor otherwise the freezer would not be working either. You might first check to see if the settings are set at the factory indicated settings, if the freezer is turned up to cold this will shut off the air flow to the refrigerator.
May 17, 2011 | Samsung Refrigerators
Refrigerator side is barely cool. Defrost light on for over a week, but unit is self defrosting??? why is ref section cooler not performing?
you have a defrost problem?all a fridge does is blow cold air from the freezer to the fridge section,when you open the freezer door you should hear the fan blowing,under the fan there's the evap coil,this is what makes everything cold,if it doesn't defrost it gets covered with ice and then you have problems or on some models there's a damper and the door doesn't open stopping the cold air from blowing into the fridge section.you'll need a meter,pull out all the food in freezer,remove all shelves and then remove the inside back wall of the freezer.with a hair dryer melt out all the ice,then find the bad part,defrost thermostat,defrost heater,bad timer or board depending on the modelwith the meter you can check the parts.also if you look down at the bottom kickplate,pull the kickplate off and look for a tech sheet,it will tell you how to put the machine into defrost,also next time send the model number so i can see what model you have,if you have a timer advance it and see if the heater comes on,also it doesn't hurt to change out the thermostat while you're in there and alot of times this is the problem,you can cut the two wires going to the thermostat located on top of the evap coil,connect them bypassing the thermostat,put the fridge into defrost,listen for a crackling sound,if you hear this the heater is on and you'll know the thermostat is bad,call your parts store,give them the model number and they will sell you the correct thermostat,if the heater doesn't come on remove the heater on the bottom and read it out with the meter,if it's not a glass heater most likely the heater will be good but check it anyway with the meter.if that's good then most likely you'll have a board problem depending on the model.hope this helps and good luck.
May 07, 2011 | Kenmore Refrigerators
Whirlpool fridge compressor will not kick in
call your parts store,give them the model number,open the fridge door on the right hand wall up near the ceiling you'll see a tag with the model number,tell them you need a start device and they will sell you one.do you hear a clicking sound or smell anything,when my device went i could smell it.unplug the fridge,remove the bottom panel in the rear and on the compressor you'll see a clip,pop it off,slide the start device off,shake it,if you hear pieces rattling around inside it,it's bad,leave the wires on until you get the new part.next time send the model number,a bad timer,board or cold control could also cause this.if the machine gets stuck in defrost the compressor won't run.if you open the freezer door and the fan is blowing,it's not in defrost and most likely it will be the start device.hope this helps.
May 07, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
IS MY TV STILL UNDER WARRENTY
Call customer service and give them the model and seriel number and they can tell you if it's under warranty.
Oct 08, 2010 | RCA Televison & Video
My fridge is working constantly it stops only when i select zero at the thermostat switch
Sounds like the cold control is bad.Does the fridge work ok otherwise?The cold control is what you are having to turn to 0,and are usually set at midrange.0 to 9,set at 4.The control has a temperature sensitive tube that opens or closes the contacts in the control,and they do go bad.This is where I would start.You can get a replacement control at an appliance shop.Get the model and seriel number of the fridge located usually inside of fridge on a tag on the inside wall.Use these numbers to get the part.Hope this helps. Gregg
May 29, 2009 | Amana ARS2464B Side by Side Refrigerator
Looking for cu. ft. info on fridge - hotpoint
It's in the model number.
ctx14<---- 14 cu ft.
Apr 24, 2009 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
